Possible problems with my sister's '00 EK Si (SOHC VTEC)
Old Aug 6, 2002 | 07:16 PM
.::miLan's Avatar
Default Possible problems with my sister's '00 EK Si (SOHC VTEC)
Today I changed the oil on my sister's 2000 EK Civic Si (CDN), SOHC VTEC.
I don't know how long she drove it after her last oil change, but she said about 9,000 Km's. I always run it with a synthetic oil, and that's about 1K too much.
Anyway. Now I hear a little sort of cliking noise, (sounds kind of like a faint tractor noise), coming from the motor. I'm not sure if I'm halucinating, just because I didn't change the oil on time, or if this is normal?
What does a healthy SOHC VTEC motor sound like when it idling? Do any of you other guys hear that faint noise when you pop the hood? Is this normal?
Somebody give me a hand here, because it's pissing me off.
Old Aug 6, 2002 | 07:23 PM
.::miLan's Avatar
Default Re: Possible problems with my sister's '00 EK Si (lowandslow)
Somebody please help!
Old Aug 6, 2002 | 07:43 PM
VtecMatt's Avatar
$20 says that it's the valves
Old Aug 6, 2002 | 08:27 PM
drvfast's Avatar
time to do a valve adjustment
Old Aug 6, 2002 | 08:40 PM
Viorent GRIP!'s Avatar
Yep I agree, either time for a valve adjustment, or if it's manual and you were brutal to the clutch it may also be the throw-out bearings, they both make similar sounds.
Old Aug 6, 2002 | 09:02 PM
POLLO's Avatar
Default Re: Possible problems with my sister's '00 EK Si (Mr. Shin)
Is the clicking noise becomes more noticeable while on idle ? Try to bleep the throttle a little bit and if the clicking noise dissapears you just need a valve adjustment. If not then check the t.o bearing like Mr.Shin said.
Old Aug 7, 2002 | 04:24 AM
.::miLan's Avatar
Default Re: Possible problems with my sister's '00 EK Si (POLLO)
The clicking noise is only present when idling...
How much will a valve adjustment run me? I'll just stroll down to the Honda stealership, since the car is still under warranty.
Old Aug 7, 2002 | 03:27 PM
.::miLan's Avatar
Ok. Well clicking noise disappeared today, but boy that is a noisy engine. Not really noisy, but noisier than my mom's Corolla...
I checked with two of my buddies today with the same engines, and theirs make that much noise too.
obuhmyuh
Feb 2, 2008 12:00 AM
Azxster
Oct 27, 2007 06:02 PM
ge_ej1
Oct 25, 2007 12:04 PM
deant
Northeast (Sales)
May 26, 2006 07:59 AM
RAF LTD.
Sep 20, 2002 10:21 AM
