Whats rods do I need to use to put CTR pistons in my B18C5?
Old Aug 6, 2002 | 07:05 PM
importadrenelin's Avatar
Default Whats rods do I need to use to pu CTR pistons in my B18C5?
EMERGENCY..
What Rods will fit CTR pistons into my Type R? The CTR Rods are .001 of an inch to wide and were sending the Pistons & Rods to the shop tomorrow to have the CTR pistons put on the ITR rods but will this even work??
Please let me know ASAP?
Old Aug 6, 2002 | 07:06 PM
Chris's Avatar
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (importadrenelin)
Stock rods will be fine.
Old Aug 6, 2002 | 07:18 PM
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (Chris)
are you absolutley sure? are there any mods that I may need to do in order to have the pistons fit that rod???
Advid please
Old Aug 6, 2002 | 07:45 PM
tonyxcom's Avatar
He is absolutely sure, as am I.
You only need to modify the CTR pistons if you are putting them onto non type r rods.
Old Aug 6, 2002 | 08:15 PM
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (tonyxcom)
what mods need to be done to the CTR pistons?
Old Aug 6, 2002 | 08:18 PM
Chris's Avatar
NONE..
You are using ITR rods. Put them in already and enjoy them.
Old Aug 6, 2002 | 11:55 PM
AJ PwR's Avatar
Balanced ITR rods
Old Aug 7, 2002 | 06:38 AM
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (AJ PwR)
hey so do I use the ITR Rod Torque Spec or the CTR Rod Torque Spec because I'm using CTR Pistons.
Thanks
Old Aug 7, 2002 | 06:44 AM
SergEK's Avatar
C5 with CTR pistons
wont your comp be a little high? What cams are you going to use? Piston/Valve clearance w/ say JUN 3's...........would the CTR's have enough room?
I was thinking B16a pistons for my R motor and that was a little over 11.5:1
B16B pistons would have a C5 well over 12:1 maybe even 12.5:1
Pump gas friendly? More info on your setup would be nice...........maybe post a dyno of before and after your new pistons
Old Aug 7, 2002 | 06:58 AM
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (SergEK)
ok so people know what torwue spec to use?
Old Aug 7, 2002 | 07:00 AM
Hey,
Actualy were using a B16A head with a Port and Polish Stage 3. Were running all CTR Valvetrain and CTR Pistons on ITR Rods. Using Bojas Calculator our Compression is 12.1:1. At least 94 Octane Gas will suffice, but to be extra safe just get the additives.....
Old Aug 7, 2002 | 07:01 AM
oldskool_rex's Avatar
don't stress out so much.
B18C5. They are probably the same anyway.
Old Aug 7, 2002 | 07:36 AM
RyanR's Avatar
Use the specs from a 73 Chevy 454 BB. I can't remember off the top of my head but I believe it's around 70lbs/ft.
Old Aug 7, 2002 | 08:10 AM
tonyxcom's Avatar
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (RyanR)
I though when you put ctr pistons in a itr you need to you prelude s torque specs
Old Aug 8, 2002 | 08:14 PM
so anyone know the specs?
Old Aug 9, 2002 | 10:48 AM
Chris's Avatar
Damn n00b... PUT THEM IN ALREADY.
They drop right in. Stop being so gullible..
Old Aug 9, 2002 | 11:53 AM
sneakychaos's Avatar
C5 with CTR pistons
12:1 assuming no material taken off the head/block and using stock 3 layer gasket. Replace gasket with 2 layer, and your upto 12.4:1.
Old Aug 9, 2002 | 12:32 PM
erottik-R's Avatar
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (C5_ALLMOTOR)
itr rods are the ones you need, be prepared to detonate
*Laughing*
Leave him/her alone...
Old Aug 9, 2002 | 01:28 PM
papasuperman's Avatar
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (erottik-R)
how much did you pay for those pistons??
and what kind of valvetrain you are using.
Old Aug 10, 2002 | 07:09 PM
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (papasuperman)
CTR valvetrain... you guys are killin me... getting me all paranoid..
Old Aug 10, 2002 | 07:25 PM
Michael Delaney's Avatar
HELP! NEED TO KNOW RIGHT AWAY!!! EMERGENCY!!!!
where's the fire? A Helms Service manual is your best friend.
Old Aug 10, 2002 | 10:13 PM
D's Avatar
D
Default Re: Whats rods do I need to use to pu CTR pistons in my B18C5? (Michael Delaney)
sup retard. i'd love to know how you plan to torque you piston wrist pins. tard
D
ZCSp0ngeR
10
Mar 2, 2009 08:48 PM
hybridpatient95
Aug 6, 2005 04:25 PM
vtec69
Aug 10, 2004 08:25 AM
ls95hatch
Jul 12, 2004 06:49 PM
tvrsir
Dec 7, 2003 10:39 AM
