stalls into neutral.. help!?
Old Jan 20, 2009 | 11:32 AM
beutler09's Avatar
Default stalls into neutral.. help!?
i live in ohio where its currently very cold out. my teg has troubles starting when i leave her out over night... once she is all warmed to performing temp ill drive it like its just fine but after driving for a white everytime i drop it to neutral to low and dies.
when warming up it stays right around 1000 RPM's but once its is all warm its around 300-500RPM's and kinda lots of shaking likes its not getting enough gas....
any ideas what might be wrong??
Old Jan 20, 2009 | 11:40 AM
Adankid's Avatar
Default Re: stalls into neutral.. help!?
fuel lines may be clogged?
Old Jan 20, 2009 | 11:46 AM
beutler09's Avatar
thats what i kind of thought.. more less frozen but i put a bottle of full line dryer in and ran that for a while... but one thing that makes me think thats not the problem is because it does idle at good rpms when its warming up so obviously its getting the fuel.
Old Jan 20, 2009 | 11:47 AM
SuzukaBlueAP2's Avatar
what year is your teg? when was the last time the fuel filter was changed?
Old Jan 20, 2009 | 11:51 AM
beutler09's Avatar
it's a 96 and honestly i really don't know i haven't owned it for that long
Old Jan 20, 2009 | 12:07 PM
rebar71's Avatar
Actually, even your cold idle is low. When you first start the car, it should idle closer to 1500 RPM until it warms up. Then drop to idle around 700 after warm.
Old Jan 20, 2009 | 05:45 PM
it might not be a bad idea to change then. And it really isn't expensive.
I picked up a 94 LS around 5 months ago and the people were clueless about it. At 134K miles it still had the original timing belt and water pump.
Needless to say I had some maintenance to perform. My fuel filter is still on my to-do list. You might want to consider that as well.
Old Jan 21, 2009 | 05:41 PM
beutler09's Avatar
i picked up a new fuel filter today and put it on. still seems to want to stall a little maybe not as bad but i did notice my air fuel gage is more reasonable.
any other reason what might be causing the stalling?
Old Jan 22, 2009 | 11:25 AM
beutler09's Avatar
bump any more help please?
Old Jan 22, 2009 | 01:48 PM
totsie7944's Avatar
Hows the clutch? I'd check your fuel pressure....any chance you can swap fuel pumps with someone?
Old Jan 22, 2009 | 05:24 PM
beutler09's Avatar
how do i check fuel pressure. and is there anyway to see if pump is going bad?
aznfish
Jun 1, 2009 04:40 AM
1989CivicSi
Jun 4, 2006 08:12 PM
R.S.
Nov 15, 2004 05:41 PM
the_eyecon
Oct 1, 2004 02:03 PM
