d-series ac on b-series motor?
it's a 93 civic with a d15b7 has ac and power steering.
i'm swapping in a b16a what do i need to do to keep the power steering and ac?
i also want to keep the ac compressor that on the car right now?
are there any oem brackets i can use?(delsol vtech "b16a3" usdm)
or do i have to use the aftermarket kits?
if so does the aftermarket kit accept the stock compressor?
thanks ahead of time any help is greatly appreciated.
Not all 1993 Civic's have R134a. R12 supposedly works better? And let's say that the A/C from the D-series works just fine. Why bother opening the system if you can't buy R12?
No '93 civic came with an R134a A/C system. ('92 - 93 = R12, '94 - '95 = R134a) In any case simply use the brackets from a '94 - '97 Del Sol Vtec to make the whole thing a complete plug and play bolt on affair.
You can, and I used to mention it a lot when these types of questions came up because its cheaper than the Del Sol bracket. however there is some confusion about using a CR-V bracket to retain power steering which is why I rarely mention it now, it does however definately work for retaining A/C, and the Del Sol bracket definately works for both.
"From 1994-present, all a/c is r134a. 1993 and below is all r12. However, apparently SOME 1993 are r134a, according to feedback from some users."
Why I brought up the r134a in the first place... *shrugs*
So Del Sol VTEC (B16) brackets are the best/easiest to use? I'd also like to keep power steering.
Thanks!
Yes, and they work for both A/C and power steering
https://honda-tech.com/forums/showth...957&highlight=
im tryin to keep my ps and ac too got good info on my thread
JDM_rolex
Nov 15, 2011 05:26 PM
