Car seems like its running rich
Old Jan 19, 2009 | 06:16 PM
90 DX Driver's Avatar
Default Car seems like its running rich
Stock d series motor in a 1990 dx hatchback it has some minor oil leaks after market exhaust and thats it
it seems like its eating gas like a semi...and the guy i bought the car from said to install a high temp. thermostat? any ideas?
Old Jan 19, 2009 | 10:18 PM
mayfly's Avatar
Default Re: Car seems like its running rich
the fuel regulator would b my guess. if its smokeing white smoke then ur timing is off. hope this helps you out
Old Jan 19, 2009 | 10:37 PM
ZC DOHC CRX's Avatar
if its running rich it would be black smoke not white
white=coolant
black=fuel
blue=oil
and there can be a number of reasons your car is running rich.a high temp thrmostat wont make it run rich
Old Jan 19, 2009 | 10:38 PM
HTautodc's Avatar
this is also my problem. it only takes me 180-190 miles before the next full tank. have you checked the o2 sensor? i'm planning to buy an o2 sensor but i'm still saving up (damn the oem is so expensive! might try the bosch one)
Old Jan 19, 2009 | 10:41 PM
dont buy bosch. had mine on my car for just about a year and the heater sensor in it went bad. buy oem!
Old Jan 19, 2009 | 11:28 PM
mitsubishiv5's Avatar
same problem with my car, CRX DX. it has oil leaks from the valve cover gasket which i will repair soon but has no effect on performance on car. car doesnt burn oil but does leak some. fumes smell nasty obviously. but cant be coolant since my cars temp never rises past the halfway mark and coolant isnt disappearing. my ignition timing is not perfect but i also have a freakin auto ecu since the engine code is flashy faulty auto trans. i know i did my walbro fuel pump, so maybe the regulator is going bad. might as well upgrade to mpfi
Old Jan 20, 2009 | 12:15 AM
HTautodc's Avatar
heater sensor? where is this located? i'm still a noob so please understand. would it be wise to buy the bosch for now to save me fuel until i have saved up for the oem? thanks
Old Jan 20, 2009 | 03:11 AM
cant be an o2 if it was i think a code would have been thrown by now.
and im not saying a high temp thermo would CAUSE it im asking if it would FIX it
Old Jan 20, 2009 | 02:08 PM
bump
Old Jan 20, 2009 | 02:28 PM
4drEF's Avatar
Keyboard Humorist
O2s can go bad and not throw a code. I've had it happen on two different occassions when getting the car smog checked. Sometimes they get 'lazy' and don't completely die.
Old Dec 13, 2010 | 11:53 PM
jaycorolla's Avatar
is it throwing a code?... it could be an injector stuck open.. ignition..
Old Dec 14, 2010 | 12:18 AM
BiG ChOr!Zo's Avatar
the op hasn't this thread in almost 2 years so he either got rid of the car or just hasn't bothered to update it...!!!
standbackimapro
Sep 22, 2007 06:49 PM
standbackimapro
11
Jun 24, 2007 01:08 PM
DarkBB4
Sep 16, 2005 10:36 AM
jspecPR26
Aug 7, 2005 10:13 AM
ramz7887
Jul 19, 2003 10:48 AM
