a little play in the hub
Old Jan 19, 2009 | 08:58 AM
PoWeRBaN_PaNdA's Avatar
Default a little play in the hub
I just recently bought 1991 honda civic EX knuckles to replace the stock dx brakes on my wagon. The guy I bought them from said all I needed to do was replace the wheel bearing on one side because the hub had a lot of play. I replaced the wheel bearing and I still have some play.
What could be the problem?
Old Jan 19, 2009 | 03:01 PM
skidmarkroyalty's Avatar
Default Re: a little play in the hub
as far as i know bearing are al that would cause play in the hub... who installed them?
Old Jan 19, 2009 | 03:22 PM
Hobby shop on base, I bought the bearing at auto zone.
Old Jan 19, 2009 | 04:39 PM
Tyson's Avatar
take an axle, tighten the axle nut to spec. then see if it has play.
if it still has play, the bearing is bad. or the hub is somehow too small. it should be obvious what the real problem is.
i only suggest new hubs with new bearings. not good to reuse old hubs in my experience.
Old Jan 19, 2009 | 05:24 PM
thanks for the help
Imprezor
Jul 23, 2012 08:37 AM
jdmcivicracer89
10
Nov 7, 2010 04:48 PM
85mmek9
Apr 17, 2009 04:49 AM
VTECROAR96typeR
Suspension & Brakes
Mar 3, 2009 12:38 PM
y49crxsi
Jul 14, 2004 10:51 AM
