HUGE WIRING PROBLEM need help integra gsr
Old Jan 18, 2009 | 10:27 PM
ricencivic's Avatar
Default HUGE WIRING PROBLEM need help integra gsr
Ok heres the low down on whats going on here.
94 gs-r
Obd2 cabin harness and dash bord installed. WHY????? i dont know just got it.
OBD2 computer harness cut off and obd1 harness clips wired on WHY???? - to cheap for jumper.
Then they wired in a vafc and a black magic modulator WTF???
Anyway i have no fuel no injecters fire nor does the fuel pump come.
Solution- replace the hole cabin harness or i need a obd2 to obd1 harness map and re wire it.
That was my plan to just re wire it no problem but the wires coming from the harness and then the wires going into the computer are two differnt colors. example yellow and black coming from harness turns into an orange and black going into the computer.
Any suggestions?? please help.
Old Jan 18, 2009 | 11:19 PM
teamworxek9's Avatar
Default Re: HUGE WIRING PROBLEM need help integra gsr
Go to a junk yard and get the harnesses that are cut and replace them. Then buy a jumper harness, they can be had for $50. Who wouldnt spend that to save this much of a hassle. Who did this or did you just get the car like this?
Old Jan 19, 2009 | 04:08 AM
ricencivic's Avatar
bought the car like this i wouldnt do this to my car
Old Jan 19, 2009 | 02:11 PM
You bought yourself a head ache. That is some hack *** shyte to do to a car, good luck .
Old Jan 19, 2009 | 03:26 PM
DrGrEeNtHuMb's Avatar
Yeah man don't president elect that shi.t, just go get a harness and replace. It might ne easier just to redo the connections but y have a frankenstein harness wen you can just get a clean harness? Then the next guy won't have to worry
Old Jan 19, 2009 | 03:39 PM
Double post
2 2 2 step!
Old Jan 19, 2009 | 06:06 PM
ricencivic's Avatar
its ok tho i got the car cheeeeeeeeeeeep
Old Jan 19, 2009 | 06:08 PM
ricencivic's Avatar
True true i dont wanna el presidenta that **** make it clean not ghetto like the white house.
jaron_cc
May 21, 2009 10:43 AM
honda_hackett
Nov 25, 2008 01:17 PM
t1ny
Apr 18, 2006 11:45 PM
lazynok
Jan 11, 2005 06:58 AM
tallblondkid
Nov 20, 2004 02:45 PM
