What's the Thread Pitch for an Accord Axle Nut?
Like the title states, specifically 94 Accord, uses 36mm axle nut. I'm stuck with stripped threads on the end on the axle, so I need to order the correct die to chase the threads to get the axle nut back on correctly. TIA
I found that a 32mm axle nut found on civics, integras, etc. is M22x1.5, but I believe the accords are bigger.
Lynn Porter
Aug 11, 2015 10:29 PM
