Thread pitch for Accord axle nut 36mm?
Like the title states, specifically 94 Accord, uses 36mm axle nut. I'm stuck with stripped threads on the end on the axle, so I need to order the correct die to chase the threads to get the axle nut back on correctly. TIA
I found that a 32mm axle nut found on civics, integras, etc. is M22x1.5, but I believe the accords are bigger.
