3mm gasket on b16
Old Aug 6, 2002 | 04:27 PM
shotty's Avatar
Default 3mm gasket on b16
Around what compression will the blitz 3mm headgasket lower my B16 to? My main concern is how much boost can the B16 take safely with the Blitz 3mm headgasket? And, how much boost is nearing the limit? I have the 15g turbo from the d-series greddy kit and I am going to bolt it to my B16. If my motor can take for example 15-18 pounds with the 3mm gasket, then I would probably get a 2mm gasket because my turbo isnt effiecient in that high boost. I need the most power possible out of 12-14 pounds of boost....so I need to match my compression ratio to that. I dont wanna have super low CR when Im not even boosting as much as it can take....that would just be losing power. ???????
Old Aug 7, 2002 | 02:00 AM
shotty's Avatar
Default Re: 3mm gasket on b16 (shotty)
ttt
Old Aug 7, 2002 | 03:13 PM
shotty's Avatar
no one knows anything?
Old Aug 8, 2002 | 02:26 AM
shotty's Avatar
Somebody????????
Old Aug 8, 2002 | 02:41 AM
Kamin's Avatar
that engine cant take 15lbs of boost
a thicker headgasket will only allow you up up the boost 1-2pounds MAYBE.
youll be lucky to run 8psi safley on the street.
dragonfly2k3
Dec 30, 2007 04:17 PM
d16z6ef
Sep 3, 2007 02:34 PM
CustomX113
Oct 8, 2006 08:42 PM
UNDER PRESSURE
Feb 6, 2003 04:48 PM
shotty
Aug 6, 2002 01:47 PM
