Half radiator help!
Old Jan 18, 2009 | 12:53 PM
StraitRunna's Avatar
Default Half radiator help!
hey guys i need to kno the best way to put a half radiator in my ef...i need the room and kant find the best way to do it
Old Jan 18, 2009 | 01:46 PM
92egvx's Avatar
Default Re: Half radiator help!
well i was looking this up...alot of people cut the two things that hold the rad up on the bottom of the rad support and then get two L brackets and weld them on lower so the half size rad doesn't sits high and so u don't have to lean the radiator back... this is the best why in my opinion and its more reliable...
Old Jan 18, 2009 | 02:02 PM
Redline130's Avatar
I would highly suggest getting an aftermarket traction bar. This will eliminate the stock front crossmember and free up a lot of room. Also look into a half sized radiator that is made to fit in the EF like the Full-Race half size radiator. A 95-99 Neon non A/C radiator fits very well too. However I never seemed to have much luck with it to keep my motor cool.
Old Jan 18, 2009 | 02:04 PM
efjones9's Avatar
or i heard that a dodge neon 95-00 year would fit, do some research youll find it
Old Jan 18, 2009 | 02:05 PM
efjones9's Avatar
my bad didnt fully read ur post man lol
Old Jan 18, 2009 | 04:06 PM
northemt88's Avatar
just get a stock replacement EG radiator, never ran hot on a turbo ls so you should be fine no matter what
Old Jan 18, 2009 | 07:29 PM
ya well im planin on droppin in a b20 vtec turbo and the room with that is not alot haha...found a top mount turbo manifold that kicks it to the side a little bit to and ill have more then enough room if i put in a half radiator opposed to a full radiator
rudebwoy
May 11, 2014 07:43 PM
aasaa666
Oct 22, 2007 08:15 PM
2 0 3
Jun 8, 2007 01:57 PM
sneakypete
May 25, 2003 09:49 AM
Etylorcen
Jul 24, 2002 12:21 PM
