how to diagnose ignition swich problem?
Old Jan 17, 2009 | 08:38 PM
turbo-crx's Avatar
Default how to diagnose ignition swich problem?
well iv come to conclude that the ignition is stuck in the auxiliary position. T the car runs with no key in the ignition, Somehow the last time idrove it and took ot the key it must have gotten stuck in the "on" postion. The only way to shut the car off is to disconnect the battery and let the clutch out and let it stall out....Good thing i have the battery relocated in my passenger seat area lol, So how would i go about fixing this issue?
Old Jan 22, 2009 | 02:28 AM
SLURS's Avatar
Default Re: how to diagnose ignition swich problem?
bump!
Old Jan 22, 2009 | 06:12 AM
civickid03's Avatar
trace the wires from the ignition switch to the main fusebox under the dash
disconnect the clip at the main fusebox and disconnect the clip at the ignition switch
ohms out each wire at both ends and then each wire to each other to make sure they arent shorted together somewhere. - there shouldnt be any ohms
between the different wires. if that checks out ok the ignition switch itself may be shorted. unplug the ignition switch wires while the car is running and
see wat happens.
you will need a multimeter
Old Jan 22, 2009 | 06:46 AM
Clipsed's Avatar
my friend had this happen to his DA recently good info
crappyshifting
Mar 11, 2012 05:35 PM
turbo-crx
Aug 6, 2009 05:13 PM
Jagan'92
Feb 20, 2007 04:54 PM
SickWitIt2.0
Jan 22, 2005 11:27 AM
ckyguy
Oct 6, 2004 09:01 AM
