Transmission question
Old Aug 6, 2002 | 02:53 PM
xxplosif1's Avatar
Default Transmission question
Ok,
I have a 1992 Integra RS. I still have the crappy RS tranny (cable) and i want something with a better gearing. I'm building a non-vtec engine and i'll stay N/A with a little bit of nitrous.
I was thinking about getting a 94+ hydro GSR tranny. Keeping only the gearing and swap it into my cable LS casing. I want to know if this bolt on or i'll need major modifications to do it. I was thinking about a del sol or an SI tranny but that'd be too close for me. The GSR would be perfect.
The cable b16 tranny would fit, but it's a pain to find one in good shape you can't find the parts for them up here in Montreal. The best bet would be the B17a tranny...but try to find one
I need input and suggestions
thanks
Old Aug 6, 2002 | 03:08 PM
Spade's Avatar
Default Re: Transmission question (xxplosif1)
If you want to use a Hydro tranny you must get a conversion.
Swapping gears is an option. Contact Mista Bone vi IM and see what he says about swapping gears, although he only has delt with D series trannies he may be able to tell you if generation swapping is possible.
To make things easy on yourself I suggest keeping an eye out for a B16 or B17 tranny.
OR....getting a cable-hydro conversion kit. http://www.hasport.com
Old Aug 6, 2002 | 03:32 PM
xxplosif1's Avatar
Default Re: Transmission question (Spade)
Yeah, I'll try to contact Mista bone, he already gave me a few tips on nitrous. I would like to stick with the cable trannys tho. I'll see.
What about keeping my RS and swapping the 3rd, 4th and 5th gear of a GSR tranny ? Would it be possible?
Old Aug 6, 2002 | 03:43 PM
88crxoncrack's Avatar
i don't think cable to hydro gear swaps work.
feel free to flame me if i'm wrong.
Old Aug 6, 2002 | 03:58 PM
xxplosif1's Avatar
Default Re: Transmission question (88crxoncrack)
I won't flame you but i believe it supose to work
Old Aug 7, 2002 | 06:52 AM
xxplosif1's Avatar
ttt
Old Aug 7, 2002 | 07:12 AM
Jeff C's Avatar
guess what i found for myself...look at my sig...
it would be a WHOLE LOT EASIER if you got a b16 cable tran
swapping gears is a little complicated, just look at the exploded views in helms
or you could covert your car to hydro, read here...
https://honda-tech.com/zerothread?id=158853
dc4ok
May 25, 2011 07:36 PM
curt801
Mar 30, 2006 08:32 PM
Orangedragone
Jul 29, 2005 01:09 PM
kaoticivic
Oct 10, 2002 08:26 PM
djlinks
May 19, 2001 09:09 AM
