stereo problesm with 95 gsr
Old Jan 17, 2009 | 07:37 PM
mannydhanju's Avatar
Default stereo problesm with 95 gsr
my stereo does not work all fuses are fine... i wired everything... harness was cut so rewired... anyone have a diagram of the stereo wiring or wat to do next
Old Jan 17, 2009 | 10:08 PM
vietnamezerice's Avatar
Default Re: stereo problesm with 95 gsr
i would double check the harness... next step would be to try a good known radio
Old Jan 17, 2009 | 11:03 PM
jerBEAR's Avatar
Was the harness put back together with butt connectors? if so, chop all of those and solder them to ensure a solid connection. With stereos, its a hit or miss. If the stereo doesn't receive power after that process, then its time for a new radio.
Old Jan 18, 2009 | 01:04 PM
Jimmy's Avatar
Global Moderator
x2.
I know you said all the fuses were good, but did you check the 7.5 amp back up fuse under the hood?
Old Jan 18, 2009 | 01:49 PM
CompanyFlow's Avatar
Yeah that backup fuse is probably the difference maker.
Old Jan 18, 2009 | 06:02 PM
dc2teg06's Avatar
Originally Posted by Jimmy
x2.
X2 I had the same issue with my head-unit awhile back.. The back-up fuse was the culprit.
Old Jan 18, 2009 | 06:45 PM
wegotmorrison's Avatar
The first thing you need to do is get a cheap wire tester, and make sure that the Power wires (red and yellow). Its that simple. If you have Power from the wires, its something you did wrong, and the fuses are all fine. If there is no power, check fuses and ****. Its pretty simple actually.
Ej1Stolo
Audio / Security / Video
15
Sep 12, 2010 06:35 PM
96GeeSR
Mar 3, 2009 12:02 PM
fortymcpants
Aug 2, 2008 01:10 PM
scorpio1472000
Nov 27, 2007 07:15 PM
Khmai_guy
Jan 16, 2004 02:53 AM
