tranny grinds in 2nd and 3rd...
so i was goin to replace the syncros (sp?) but honda does not sell just the syncros (brass colored things...i think). so what do i need to look at to find out what to replace? would i just need to replace the countershalf parts or the mainshaft parts or does it depend. btw, i have the tranny open. the only wearing i can see is on the gear just above the 1st gear on the counter shaft (closest shaft to diff).
Bottom Line: If tranny is grinding, with it apart what do i need to look for?
You will need a complete gearset for the grinding gears. Usually 1st synchro and 2nd gear are together in a set and 3rd is separate (d series). In other words, you would buy a 1st and 2nd synchro set which comes with second gear,1st and 2nd synchros, and reverse gear- and 3rd gearset which comes with 3rd gear and 3rd synchro set. A new 2nd gearset for a d series will set you back @$300 new from Honda. Unsure on B series gearing, haven't had to work on one yet.
[Modified by fixhondas, 5:55 PM 8/6/2002]
so then which of these should i get...
1) item 4 in this first one (countershaft)
or
2) items 4 and 8 in this second one (mainshaft)
which do you THINK would cover my 2nd and 3rd gear synchro problems
here are the direct links to the site
http://www.acuraautomotiveparts.net/...RSHAFT+%282%29
http://www.acuraautomotiveparts.net/...NSHAFT+%282%29
i can scan in my helms pages for a better explode view
[Modified by Jeff C, 6:49 PM 8/6/2002]
or
#4 (15940) on countershaft is 1-2 synchro set plus 2nd gear, you need this. If you have trouble with grinding into first gear, I would also get #2 (15843) but I don't think you need it. #4 (15994) on the mainshaft is 3-4 synchro set plus 3rd gear, you need this also. If you look these up on Honda's computer they will have gear numbers in their description.
after going back and forth between helms, the acuracarland diagram, and the physical gears, i see what you are talking about. all the synchros that appear to have wear are covered in item 4 in both the countershaft diagram and mainshaft diagram.
the shiftforks dont look brand new but they look alright.
this is going to set me back a little more than a i thought but i will practically have a brand new tranny.
thanks for your help.
iBrandon
Aug 23, 2007 12:17 AM
