Can Head go on without cam installed
doing a head gasket..my cam is out...can I install the head without the cam being installed??
My thought was to put the crank #1 TDC and then when I put the cam in set it in and tighten the rockers with it sitting at #1 TDC??
Will this work??
Will this work??
you have to torque the head down befor you button the cam in,theres a few head bolts that you can not get to with the cam in the way.and for the cam at tdc issue , dont quote me on this but i dont think it matters ,adjusting the timing will take care of it.
next time include your engine type,and maybe some more details .
as for cams on a tdc. that is a true statement. it DOES matter. sometimes it can be a pain but its not hard at all. just think if you had you cam in at tdc on cylinder 3 and your crank at tdc on cylinder 1..... can you say valve catastrophe?
blackeg
Dec 30, 2003 11:00 AM
Rob Dizzle
Dec 8, 2003 06:04 PM
