wana paint my valve cover
Old Jan 15, 2009 | 05:18 PM
-=ZAK=-'s Avatar
Default wana paint my valve cover
so i wana paint my valve cover with the rising sun.
duno if i should go red/white or red/black my car is red.
what kinda paint would be best for it?
any tips on getting good straight lines and as close to a perfect circle as possible.
there was an "official paint your own valve cover thread" on the old forums but i cant find it anymore.
Old Jan 15, 2009 | 05:28 PM
green99civic's Avatar
Default Re: wana paint my valve cover
make sure you get heat paint or caliper paint and i would go with black if it was mine. Just make sure u use just normal paint
Old Jan 15, 2009 | 06:20 PM
shiux's Avatar
any temperature paint will work.
how hot does your engine get? I havent seen any automotive spray paint that isnt rated high enough, and Ive used it all, even touch up paint for the exterior of a car without any issue.
Old Jan 15, 2009 | 06:24 PM
-=ZAK=-'s Avatar
i have some caliper paint. im pretty sure my brakes get hotter than my valve cover. is there anyway to get near perfect lines on a valve cover with all the ridges and stuff
Old Jan 15, 2009 | 06:31 PM
onefastcx's Avatar
use tape to mask it off
Old Jan 15, 2009 | 06:45 PM
Search-first's Avatar
You saw the one I did at that honda-tech meeting didn't you. Took me a little while to tape it off, and I used dupont automotive paint, with an etching primer over the bare metal, and then a small layer of 2k primer, and then white base, then red base, then shaved the paint off the lettering, then cleared it. Cost me about $50 to do it. Now it's on my buddy's hatch. I traded it off when I got rid of my built Ls/vtec I had.
Old Jan 15, 2009 | 07:42 PM
hondafab19's Avatar
i would go with red/black, because it probably easier to clean
if it gets dirty..and just use a high heat or caliper paint and
should work fine,also make sure you sand it good enough
and have no grease on the surface..hope this helps and good
luck.
b0mb5
Aug 24, 2008 08:16 PM
jsteezy1290
18
May 12, 2004 08:59 PM
SmokyMtnRex
Mar 23, 2002 09:21 AM
vtec-outlaw
Feb 4, 2002 04:53 PM
