Tranny grinding gearz
hey i have a 1990 integra ls ok will i just want to know what could it be the problem with my tranny grinding gearz it mostly grinds reverse and 1 sometimes and 2 when i beat on it . also my clutch is shot like really shot im going to change it in the summer but yea could that be a problem and also i didnt check my tranny fuild but im pretty shore thats very low also
thanks for all ur help
change your trans fluid and change your clutch and you cant be rolling when you put your car in rev put it in 1 then r for better shift, use good parts not ebay stuff later
i dont know his saying that the car cant be rolling when you put it in rev and im saying its not i come to a stop and when trys to put it in reverse it grinds and it been grinding in 2 gear alot now it sucks that it winter time or i would put a clutch in. i hoping changing the fluid will help
you can grind reverse if your not moveing...
If you clutch is bad you input shaft is still under a lil bit of torque from the motor...and it will turn the input shaft just enough that the reverse gear will not slide in to the gears on the input shaft...
Hope that you find this helpfull
iNDyCRX
Feb 23, 2008 08:31 AM
