s2000 valve train...N/A tuners???
Surje.motorsports
can i use the s2000 valve springs and retainers in the k20a2? i was reading something about stage 2 cams and saw something that mentioned this but dunno for sure, any help is appreciated...thanks
I had a post about this issue too. But from wut i heard is that you can use it but you have to use different cam shaft. but your using skunk2 so i guess that would be a problem. but just incase, you should ask skunk2 about that.
Surje.motorsports
Surje.motorsports
my bad i misread stage 2 for skunk2. reading to fast. lol
As far as the valve springs, I would go with what the cam manufacturer advises.....Some manufacturers design their cams for stock valvetrain (Tokoru) and others recommend an OEM combo consisting of the type-R inner spring and S2000 outer spring (IPS).........
umm keepers.. valve stem locks i guess they could be called. the two little claws if you will that lock the stem in place to keep it atached to the retainer.
