1996 Accord Electrical Problem
Old Jan 14, 2009 | 12:42 PM
96TightAccord's Avatar
Icon2 1996 Accord Electrical Problem
Hi I own a 96 honda accord ex and I just had new engine put in. It's the same engine 2.2 Vtec SOHC. My brother put it in for me, but it's having some electrical problems. All the dash lights will stay on with no key in, the heater will blow, it seems like everything is wired to the battery. I have a brand new battery in it and it keeps dying. Any suggestions or somewhere to start. Thanks
Justin from Michigan
Old Jan 14, 2009 | 02:46 PM
alkoholikwun's Avatar
Default Re: 1996 Accord Electrical Problem
it does seem like everything is wired to the battery. i recently did the swap by "myself" and all the electrical connectors should be plug-and-play for the most part. make your brother back-track the electrical connectors.
Old Jan 14, 2009 | 04:25 PM
Are all the electrical connections buried under the dash? My bro lives about 200 miles away. Where should I start looking?
Old Jan 14, 2009 | 10:14 PM
with my swap, i didnt have to mess with any wires located inside the car, mostly messed with wires in the engine bay, except wiring up ecu on passenger floor board. main wire i dealt with was the engine harness, then certain plugs had to be spliced from original harness to fit new/different plugs on harness. when i bought my motor, it came with the complete harness for it, but the ends were cut-off.
you probably have a short or something.
when your brother did the swap, he didnt need to mess with any wires inside the car such as the dash and such. like me, the main thing he would have messed with would have been the engine harness.
Old Jan 15, 2009 | 10:25 AM
masterkill455's Avatar
check for stuck\shorted relays
Old Jan 15, 2009 | 11:15 AM
craiger28's Avatar
Does your car have an alarm???
Old Jan 15, 2009 | 11:18 AM
chiaxi2002's Avatar
Check all the fuses.
Old Jan 15, 2009 | 12:26 PM
DrZFiNeSt's Avatar
Check all your grounds and connections to make sure you don't have a short or an open circuit somewhere.
Old Jan 15, 2009 | 02:15 PM
I don't have a car alarm. Thanks for all the help. I'll check all the fuses first I suppose. Not sure where the relays are. Can you guys give me some pointers on how to check for shorts? I'm a little overwhelmed.
Old Jan 15, 2009 | 02:19 PM
the other thing is you could disconnect the ignition switch and ohm it ou with a meter to see if the ignition switch itself has shorted
Old Jan 26, 2009 | 04:44 PM
heres an easy start: take a multimeter or a test light, ground one lead and see if theres power coming off the accesory or ignition wires when the key is off. If you cant get a diagram, there should only be one wire that has power with the key off, and thats the battery power wire. If you got more then one wire with power, your ignition switch is bad. To make sure it is, unlug the connector to the switch and if everything shuts off the switch was bad. If it dont, the problem is elsewhere. Let me know and ill see if I can help you out more.
htimsda
Honda Accord (2013 - 2015)
Jan 5, 2019 04:42 PM
mhmorgan3
Nov 10, 2015 08:55 AM
Meter
Mar 17, 2015 07:32 PM
DR gonzo MD
Feb 6, 2014 11:24 AM
01accord2.3
Sep 2, 2010 11:34 AM
