Alternator Compatibility-Different Part Numbers
I own a 97' RS and I want to know if the following alternator will fit?
The part numbers for stock alternator between V-Tec and Non-Vtec models, stock, are different.
http://cgi.ebay.com/ebaymotors/ACURA...Q5fAccessories
Also, would you recommend it? It's a rebuilt Nippodenso with 1 year warranty for those that have ebay blocked...this description...
ACURA INTEGRA ALTERNATOR HIGH OUTPUT 130 AMP
Remanufactured For Maximum Performance
Satisfaction Guaranteed
Grand Rebuilders Inc.
From collectibles to electronics, buy and sell all kinds of items on eBay Stores
This is a Nippondenso alternator Remanufactured for the following applications:
Acura Integra 1.8L VTEC 1996-2001
except Type R
130 Amp
ONE YEAR WARRANTY.
except Type R
130 Amp
ONE YEAR WARRANTY.
u can correct me if im wrong but, there is a differance between the alternators, one is offset different , bascially the belt will not line up, i think the gsr is the only one that is different
Ok, just for reference purposes...
I changed it today(on a lift) and everything went smooth. This alternator listed as a GSR was not offset with the crank pulley and the clip fit perfectly.
The easiest way to remove the alternator from the engine bay is to remove the driver's side axel AND intermediate shaft. At first I was going to remove the lower alternator bracket, but one bolt is extremely hard to reach from the top or bottom of the car.
I hope this helps someone.
130, 130amp, altenator, alternator, alternators, amp, bolt, compatibility, compatiblit, grand, hondatech, integra, lower, nippondenso, no, numbers, part, rebuilders
