RPM's drop suddenly when clutch is engaged/clutch noise
Hey guys im having some issues with my RPM's dropping and clutch is making noise.
Lets start with the RPM's.
I get in the car, shut the door and start the car. After the car is warmed up and been driven around to normal operating temp. I pull up to a stoplight and push down the clutch, the RPM's drop down to 400-500 then back up when I release the clutch.
Clutch noise:
Well about a week ago I knew I had the throw out bearing issue. But last Sunday night I was driving home and I was accelerating on the on ramp and redlined 2nd gear then shifted into third fourth fifth etc. (I didn't redline all the gears just second.)
Well when I got on the offramp and got to the light I put the clutch in and the "throw out bearing noise" got WAY worse or something happened. Thats also when the RPM problem started.
What did I do and what needs to be fixed? Thanks
Clutch noise:
might as well buy a new clutch and do that while your at it... some clutchs kits come with a bearing
id say the same thing
85_305
Honda Civic (2001 - 2005)
41
Apr 26, 2021 07:43 AM
DeeJaaY209
14
Sep 15, 2013 10:40 PM
levifps
Jun 25, 2007 12:16 AM
