What ecu for a 91 Teg with LSVTEC
Old Aug 6, 2002 | 08:08 AM
WAFFLES's Avatar
Default What ecu for a 91 Teg with LSVTEC
I'm trying to settle this between a friend and myself...He says you use a P30 and I said you can't and that it need to be a PR3. Who's right?
Old Aug 6, 2002 | 08:23 AM
Spade's Avatar
Default Re: What ecu for a 91 Teg with LSVTEC (WAFFLES)
P28.
Old Aug 6, 2002 | 08:34 AM
WAFFLES's Avatar
Default Re: What ecu for a 91 Teg with LSVTEC (Spade)
p28-obd1
I thought 91 tegs were obd0
Old Aug 6, 2002 | 09:52 AM
DR. ON POINT's Avatar
Banned
u can use either the PR3 or the P30, they are both non OBD
Old Aug 6, 2002 | 09:54 AM
WAFFLES's Avatar
Default Re: What ecu for a 91 Teg with LSVTEC (On Point EK!!!!!!!!)
really, I thought p30 was obd1 from the del sol
Old Aug 6, 2002 | 06:08 PM
Banned
I dunno, do a search and find out...now I am confused
Old Aug 6, 2002 | 06:11 PM
bryant's Avatar
Well i do know you gotta use an OBD0 and for sure the PR3 and PWO are.
Old Aug 6, 2002 | 06:51 PM
eg6ajk's Avatar
best choices would be :
PR3 and PW0 as they work with nonobd electronics and plugs and have DOHC VTEC capable maps and sensors.
PR3 can said its a slightly better choice as more ECU programs are offered for the ecu (such as no knock sensor or 2nd 02 disabled)
other choice is to use chipped PR4 ecu (rs/ls/gs 90-1) + vtec controller
Old Aug 7, 2002 | 07:31 AM
WAFFLES's Avatar
Default Re: What ecu for a 91 Teg with LSVTEC (eg6ajk)
Thanks everyone for your help.
Old Aug 7, 2002 | 08:25 AM
riceboy's Avatar
I'm using a PR3, works just fine. Throws a code for the knock sensor though.
Old Aug 7, 2002 | 09:14 AM
ToxxicSol's Avatar
Default Re: What ecu for a 91 Teg with `
I have a 94 Sol, and the stock ECU is a P28, which was with the B16, I did the LS/VTEC bottom end swap, and the P28 works great, but if you really want results the best combo I have seen is the Mugen spec ECU... my 2 cents
[Modified by ToxxicSol, 6:14 PM 8/7/2002]
DRAG_WORKX
Jan 15, 2007 08:07 AM
Nisif
Apr 11, 2005 12:47 AM
ITR.#1446
Mar 8, 2005 09:09 PM
jondancer
Jun 25, 2004 08:02 AM
stizzit
Dec 7, 2002 06:41 PM
