Issue w/ 1998 CRV help!
My parents 98 CRV's today had some weird issue. All of a sudden, all the power window/lock/mirrior doesn't work. Was wondering if its some specific module gone bad?
Any suggestions where i should start to look into?
Thanks
Thanks
Haha, mine has the same problem too.
Take a look at the wire loom going into the door.
I messed with mine, and it got even worse.
I haven't even bothered to mess with it, so I don't know how to fix it, yet.
The above two are probably right. Take the door off by removing the 4 12mm bolts on the hinge and unplug the harness from the door. You can then replace the wires as needed.
DAP97SI
Apr 22, 2011 05:28 AM
CaptivaBlue
10
Feb 27, 2005 10:24 AM
