Power Window doesn't work with door open?
I noticed that my power windows or locks don't work when the drivers door is open, is this normal? I have a 97 civic hatch with the power window conversion. They work fine when the door is closed but don't work at all when it is open. Just trying to find out if this is normal or if I have a problem that I need to fix.
Re: Power Window doesn't work with door open?
Depends on how the pw were installed... We can't tell you because we didnt install it. My guess would be the way you wired it, the power is cut off when the ajar door sensor is activated...
or the wire's in your floor harness are starting to break . look on the inside of the plug that goes into the door . the harness i got had 14 broken wire's out of like 17 .
Chance EG
01-11-2017 01:52 PM
Kyle700
12-10-2014 11:32 AM
Rayz_Si
04-21-2008 06:17 PM
DJNauTicz
12-03-2006 06:37 AM
