97 Accord - Spark problem / Car won't turn over
I have a 97 Accord EX with an H22A swap.
The problem I've been having was somedays the car would start but others it would turn over but wouldn't start.
A couple of days ago I tried to start my car and it wouldn't start. I think it's officially crapped out because it hasn't started in 2 weeks. But I checked to see if I was getting spark and the only time I do is when you turn the key. When you try to start it there is no spark.
I changed the ignitor on the Dizzy and also tried replacing the coil but still nothing. Anyone have any suggestions?
replace your cap, rotor, plugs and wires. Do that, and if u still have a problem, i would check your fuel system. Good luck, wish I had a H22 in my accord!
Also pay attention to the weather, does it it only happen if it's really damp, humid, rainy out. Thats what happened with me, new cap, rotor and o ring seems to have solved it 90 days later. Moisture can also foul old plug wires so do a resistance check on them in damp conditions. Other than that like the poster above said check spark and fuel, as long as it cranks the starter and battery should be ok.
Make sure you post a solution when you get it figured out.
1997 Honda ACCORD Recall ID from NHTSA: 02V120000
Auto Recall Date: 05/16/2002
Vehicle Component: ELECTRICAL SYSTEM:IGNITION:SWITCH
Estimated Vehicles Affected: 1000000
1997 HONDA ACCORD Defect Summary:
ON CERTAIN SEDANS, COUPES, HATCHBACKS, AND SPORT UTILITY VEHICLES, ELECTRICAL CONTACTS IN THE IGNITION SWITCH CAN DEGRADE DUE TO THE HIGH ELECTRICAL CURRENT PASSING THROUGH THE SWITCH WHEN THE VEHICLE IS STARTED.
Defect Consequence:
WORN CONTACTS COULD CAUSE THE ENGINE TO STALL WITHOUT WARNING, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPLACE THE IGNITION SWITCH. OWNER NOTIFICATION BEGAN JUNE 14, 2002. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT HONDA AT 1-800-999-1009 OR ACURA AT 1-800-382-2238.
Notes: AMERICAN HONDA MOTOR CO.,
It could also cause a no start conditon...
Give your local Honda dealer a call, and ask if your car's VIN is involved - if it is, it won't cost you a thing. If not, you know what you've got to look at.
P
Well................... there's this:
Defect Consequence:
Remedy:
P
Defect Consequence:
Remedy:
P
