Wet won't start 97 Accord
My daughter has a 97 accord, the car works great.......if we get a heavy rain, it will not start.
Turns over, but won't even try to start.
She can park the car at night, it rains , no start in the morning...........let it sit for the day after it stops raining.....starts and works fine.
I've checked the cap,wires, soaked all the wires with silicone spray, doesnt seem to help.
Any ideas of what else to check or do ?
Thanks
Thanks
Re: Wet won't start 97 Accord
I had the same problem with mt 94' EX. Whenever it rained it wouldn't start. Then the starter went from cranking it so much($105) the shop I took it to told me I needed a main relay ($70) plus $347 labor. Then I replaced both battery cables ($32 & $64). I still had the problem. Turns out it was a bad engine computer it took me months to figure it out. I got a used one on Ebay for $42 and never had the problem again. Look under the glove box for two blue plugs, pull the one with two wires in it, unbend a paper clip and stick one end in each hole,turn key to 2, If it's an automatic the D4 light should give one long flash and four short ones (code 14 faulty ECM). Good luck
projektt
01-20-2009 02:16 AM
tjohnson329
08-14-2004 12:02 PM
