how do i open my car?
Old Jan 13, 2009 | 11:08 AM
nickoz's Avatar
Default how do i open my car?
I have a 1996 honda accord ex... and my door wasnt opening from outside... well i new about htis for long time... didnt fixx it cuz its cold out wanted to wait till summer time. well now inside wont open... and the pull lock thingy wont move... like its jammed or the rod is off... welll to get to the point...
car door wont open.. how do i get this open. i tryed pulling so many screws of what i can to try to pop it open but nothen.. has anyone has this problem before?
PLZZZZZZZ help... got baby and its pain n assssss now to go through my 2 dooor accord... well one door now...
Thanks n advance.
Old Jan 13, 2009 | 11:15 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: how do i open my car?
Do a search, there's a point you can drill on the lock and then you can replace it.
Old Jan 13, 2009 | 11:22 AM
Crank's Avatar
go thru the trunk.
Old Jan 13, 2009 | 11:58 AM
nickoz's Avatar
there has to be another way besides drilling. as for trunk why trunk? i can get into my car and open drivers dooor ...etc... but passenger dooor is not opening either from outside or inside.
Old Jan 13, 2009 | 12:21 PM
Like I said.
Do a search, it's some issue with the lock, you take off the door panel, take off the plastic weather guard and then drill a point on the lock, it opens, you replace the lock with a new working one.
Done
Old Jan 13, 2009 | 12:30 PM
high_society's Avatar
You need a new lock mechanism. If you don't want to drill a hole to replace it, then get used to not being to open that door.
Old Jan 13, 2009 | 12:39 PM
nickoz's Avatar
yah i gotta replace the key hole outside the car?
and how do i take off the panel if the door wont open?
Old Jan 13, 2009 | 01:30 PM
P_Adams's Avatar
You may have enough room to get the interior panel off to gain access to the interior if you fold down the interfering seat back.
The panel is held on by a series of clips and screws.
The screws are located behind the speaker grill, the interior relase handle trim and other locations. Once you get all the screws addressed, along with the armrest, the clips will just pop out and release the panel.
What happens next will be determined by what you find
This may help
http://www.hondaautomotiveparts.com/...NT+DOOR+LINING
P
Old Jan 13, 2009 | 02:26 PM
nickoz's Avatar
but ur saying i should be able to do this while the door is closed?
i kno there is a few i wont be able to get in at because the Dash baord... it would the clip on top very left... on that diagram.
Old Jan 13, 2009 | 02:29 PM
Crono139's Avatar
Personally, I don't think you'll be able to get the panel off without opening the door.
Some of the clips won't be accessible.
Old Jan 13, 2009 | 04:34 PM
P_Adams's Avatar
That's why I said "May"
The only other recourse you may have is to modify a SlimJim (official B&E tool) and see if you can hook a release lever on the lock to pop it open.
Other than that and I've no other suggestions but to see if a local bodyshop has an answer.
Old Jan 13, 2009 | 06:21 PM
DrZFiNeSt's Avatar
I had the same issue with my accord what happened was this piece that looks like a hanger fell out off place but it's gonna be a PITA to get the panel off.
Old Jan 13, 2009 | 06:43 PM
96f22b2's Avatar
You could take the seat out...
Old Jan 13, 2009 | 09:31 PM
stereo69's Avatar
take the door panel off theres just enough room to do it but barely, what you have to do is take off all the screws the mirror cover roll the window all the way down from there pull the panel off from the top where the glass is and once it's loose pake a flat head screwdriver put it between the panel and door where the mirror is to pop the fastner loose. easy as pie! just that if you don't get the door open it's not going back on! but next time fix the little problem before it get this point where it's big pain.
Old Jan 14, 2009 | 12:34 AM
gonnatell1's Avatar
Not specifically for your year but you can use it as reference. Just check out this site.
http://techauto.awardspace.com/doorproblem.html
CaspianSeayaker
Feb 8, 2015 07:00 PM
Mikejar123
10
Aug 30, 2011 10:03 AM
chiaxi2002
Jul 22, 2010 10:45 PM
HennessyLane
Jul 30, 2009 09:32 AM
ripjar08
Sep 19, 2008 08:27 PM
