DYI: DA Passenger Waterleak fix with pics
Old Jan 12, 2009 | 07:45 PM
crxstylin's Avatar
Default DYI: DA Passenger Waterleak fix with pics
I saw a post requesting this in the FAQ and I had a friends car to do this on so I took pictures
If you have ever had that annoying waterleak that comes in around the blower motor on the passenger side floorboard and wondered how to fix it, heres how.
You will need
Eight grommets from Acura part # 91608-SJ6-003 cost around $20 total for all 8
Jewelers screwdriver
Needle nose pliers
14mm socket with ratchet
Number 1 size phillips screwdriver
Flat screw driver
New parts
What you will be removing
Use needle nose pliers to remove each of these (there are several of them, I think 8 in total
Press on sides with pliers and push up
Here is what it looks like removed
After removing all of the push in retainers remove the wipers, each requires a 14mm socket, after removing the nut wiggle the wiper in an motion toward you for it to pill out
Remove all 6 of these by pullng them out, it might require a flat head screw driver to get it started
Pull this part of the plastic molding out from where it meets the hood. Do this on both sides of the car (no tool required)
Zip tie temporarily (or tape) the plastic molding up and out of your way
You will now be removing this
Using number 1 phillips screwdriver removing each screw, be careful as they are 15 year old plastic screws (if one strips on you yank it out)
After removing all 8 screw remove the piece that the screw went in to. Simply get under it with a flat screw driver and it will come out easily
Remove plastic
This is the reason why your car leaks right here. Remove the old grommet as seen on right, new one is pictured on left
clean area where grommets go with damp cloth, dry surface when done
Install 8 new grommets
Push in screw retainers (be careful not to rip the new grommet when pushing these in.
Put in screws (some of them might not thread but you can tap them in with an extension and hammer if need be)
Install everything else in the reverse order and you are done
Old Jan 12, 2009 | 07:57 PM
MD426's Avatar
Default Re: DYI: DA Passenger Waterleak fix with pics
Great write up. I need to do this. I'm going to just fill those old grommets with silicone for right now. That should work right?
Old Jan 12, 2009 | 08:01 PM
crxstylin's Avatar
It works, and i did it on my car butttttttttttt. My wiper motor went bad and I could not remove the silicone so I had to pry open the area and work around it, the choice is yours as always. $3 tube of silicone vs $20 @ acura, not too bad getting the actual part from Acura and my Acura that never has anything in stock had this
Old May 19, 2009 | 05:30 PM
crxstylin's Avatar
This just in about 1 1/2 years after the silicone repair it is starting to fail. Saw some water coming in the other day. If anyone can think of any improvements that need to be done to the write up, let me know and I will do them when I do my car the right way.
Old May 19, 2009 | 05:45 PM
jhammond_82's Avatar
Reject Papi
i didn't use the silicone grommets from honda. i just used silicone in the holes. then around the black peice where the black foam seal is, i used more silicone. i think it'll be ok. it hasn't leaked yet, and we've had some hard rain since i've don it.
Old May 19, 2009 | 05:53 PM
WDG_729_ITR's Avatar
Looks like your car spent a little too much time in the enchanted forest.
Old May 19, 2009 | 06:10 PM
crxstylin's Avatar
This is how I did my car, it has since failed. The grommets on my friends car has not failed yet.
The red car was not my car, it was one i had the chance to do a how to on.
Old Jan 10, 2013 | 09:17 PM
wuteng's Avatar
that should solve the water leak in the passenger floor but can anybody explain water getting in the spare tire location.....
Old Jan 11, 2013 | 03:52 AM
Mr. DB2's Avatar
Most likely cause is,bad taillight gaskets.
Good write up on cowl repair. I did a ton of these when I was a honda/acura tech back in Florida.
Old Jan 12, 2013 | 01:54 AM
reddragon102's Avatar
Good to know ill will do the same when fixing up my project.
Old Nov 12, 2016 | 11:05 AM
Krazy613's Avatar
Hey my car 98 integra broke down wouldn't start twice for me after I seen my trunk had 2inch of water in there and under the back seat where the fuel pump wires are. They were a big ball of carroision. Put new connector in from junk yard and no problem since. But my drivers side tail light also has some water in it but I don't know how. Please help my trunk has nothing in it so I can try and find where it's coming in but still see nothing. Thanks.
Toe_Knee
May 23, 2012 03:00 PM
Mugen Mike
Jun 7, 2008 08:13 AM
Gumbey75
19
Dec 10, 2004 06:39 AM
crazyteg95
Oct 13, 2004 03:07 PM
lilcasino
Sep 24, 2002 08:22 AM
