How do you know if you have a bad radiator fan timer?
Old Jan 12, 2009 | 04:55 PM
supermotothud's Avatar
Default How do you know if you have a bad radiator fan timer?
96 VTEC 2.2 4 cycl.
over 200k
im overheating badly. still cant figure it out...all the coolant sensors and fan sensors have been replaced.
it only over heats when i come to a stop. the fan works with the AC..but not without it.
Bad radiator fan timer???
Old Jan 12, 2009 | 07:02 PM
hondadude's Avatar
Default Re: How do you know if you have a bad radiator fan timer?
I hope this info helps you;
here's a link so you can view it better;
http://img248.imageshack.us/img248/1...fncntrluf4.gif
Old Jan 12, 2009 | 07:03 PM
Paul-R's Avatar
When your fan doesn't come on at the right moment you can check your manual to see fan specs. When your car get to a high temp and fan isn't on then you have a problem .
EGed up from the seat up
18
Jun 1, 2011 02:16 AM
r33dm0n3y
Jul 7, 2008 10:18 PM
kyle h.
Welding / Fabrication
Jun 22, 2005 07:18 PM
mike93eh
Mar 26, 2005 03:04 PM
