CTR pistons VS .25 oversize??
Old Aug 6, 2002 | 02:11 AM
evo's Avatar
evo
New User
Default CTR pistons VS .25 oversize??
What advantage would I've if go for 0.25 oversize CTR pistons compare to standard one?
It'll be in B16!
thanks
Old Aug 6, 2002 | 03:09 AM
evo's Avatar
evo
New User
Default Re: CTR pistons VS .25 oversize?? (evo)
anyone.
Old Aug 6, 2002 | 08:09 AM
martini's Avatar
well, you are cleaning off the cylinder walls, so you can start fresh with the new rings.. And you are going to be increasing displacement slightly, and increasing the compression ratio slightly..
Is that enough?
[Modified by martini, 9:09 AM 8/6/2002]
Old Aug 6, 2002 | 09:26 AM
evo's Avatar
evo
New User
Default Re: CTR pistons VS .25 oversize?? (martini)
My car has done 120,000miles already do u think is better use .25 oversize or standard one?
Old Aug 6, 2002 | 09:33 AM
ITC Racer's Avatar
To overbore or not will depend on if you think the cylinder walls are scored or not or if you feel you need/want the extra bit of displacement.
I rebuilt the engine in my 85 CRX Si and started with an engine with ~160k on it. I only needed to recrosshatch the cylinder walls and use new rings and it ran great. This was in a street car and I did not want to pop for new pistons so just bead blasted the old ones and reused them.
Good luck
Old Aug 6, 2002 | 11:34 PM
evo's Avatar
evo
New User
Default Re: CTR pistons VS .25 oversize?? (ITC Racer)
How much BHP difference would I get over the standard one, assume it had all bolt on.
thx
Old Aug 9, 2002 | 11:26 AM
rotten's Avatar
The oversize will increase the compression ratio slight. THey CTR pistons will increase the CR significantly.
Stock (PR3): ~10.2
.25 Over PR3: ~10.25
CTR Standard: ~10.8
CTR Over: ~10.85
10.85 CR should still be able to use 92 Octane fuel without detonation... should have a fairly significant hp/torque improvement, how much I'm not sure.
Old Aug 21, 2002 | 10:40 PM
MisterB's Avatar
Default Re: CTR pistons VS .25 oversize?? (rotten)
you wont feel the dif between std and os... but it is nice to know that your walls are in perfect shape after the bore and hone when using os pistons
[Modified by cl4show, 7:40 AM 8/22/2002]
Old Aug 22, 2002 | 02:07 AM
evo's Avatar
evo
New User
Default Re: CTR pistons VS .25 oversize?? (cl4show)
I'm still unsure what's the difference between Crosshatch and Hone??
Can anyone explain to me, Thanks..
Old Aug 22, 2002 | 03:26 AM
sparkz's Avatar
Basically honing means the process giving it a crosshatch.
Old Aug 22, 2002 | 06:15 AM
X2BOARD's Avatar
Default Re: CTR pistons VS .25 oversize?? (sparkz)
The cross hatch is the result of a good hone job.
To the guy that said there would be a compression increase from the 0.25 overbore.... how do you figure an increase in displacement to give an increase in compression ratio ?
CTR's will give more compression= more Hp/tq and the overbore will give you more displacement=more hp/tq... might only be like.. 2-4hp (from overbore)... but something !
X2
Old Aug 22, 2002 | 07:30 AM
Katman's Avatar
Honing is when a block's cylinder walls are bored out to fit an OS piston or whatever sized piston into the block; or make the diameter of the cylinder walls wider to allow an OS or other larger diameter piston to fit.
Crosshatching is either performed during the honing process or after the honing process. Crosshatching ensures a good seal for the piston rings. They're criss-crossed lines that you can visually see on the cylinder walls, created by a honing tool.
Old Aug 22, 2002 | 08:02 AM
X2BOARD's Avatar
Default Re: CTR pistons VS .25 oversize?? (Katman)
Honing is when the cylinder walls have a very small layer 'sanded' off to create a smooth, cross hatched surface... the cross hatch is a RESULT of honing... it's not done at the same time. Honing gets rid of small imperfections and the seating created by the previously used rings. Without it done, you can get some compression loss thru deeply seated gooves.
BORING (to get the cylinder BORED) is when you increase cylinder wall internal diameter for a larger piston.
Honing still does widen the wall (very slightly), but is not meant to increase bore, just to smooth the walls, which is one of the reasons you should ALWAYS use new rings on a freshly honed block.
X2
Old Aug 22, 2002 | 08:11 AM
Katman's Avatar
Default Re: CTR pistons VS .25 oversize?? (X2BOARD)
X2
o word thanks for the clarification.
you 'honed' my reponse
[Modified by Katman, 9:12 AM 8/22/2002]
Old Aug 22, 2002 | 10:59 AM
martini's Avatar
Think about it.
Increasing the bore will increase the volume of the combustion chamber at BDC by quite a bit, at TDC, you will be very close to having the same volume as the stock bore. Take into consideration the piston-to-deck clearance is only .0762mm, and the headgasket bore may be increased slightly, but the head remains untouched.. So as long as the piston-to-deck clearance plus the headgasket thickness times 10.2 (or whatever your compression ratio was before the bore), is less than 89 (or whatever stroke you are using), it will increase the compression ratio.
I could go into all the math and such of it, but I think if you think it through, you'll understand, it's pretty simple. Maybe I just confused you more though.
Old Aug 22, 2002 | 11:22 AM
X2BOARD's Avatar
Think about it.
Maybe I'm not using all of my brain due to being at work and all, but I still don't get it ?!
I am trying to understand your explaination, but a .25 overbore is an OEM option and it does not require modification to the combustion chamber nor does it require changes to headgasket diameter
X2
Old Aug 22, 2002 | 05:52 PM
martini's Avatar
ok, so if it requires no modification to the combustion chamber or headgasket, then how is there an increase in displacement?
When putting in the .25mm overbore pistons, you need to have the cylinders bored out by .25mm.
Old Aug 22, 2002 | 10:47 PM
rotten's Avatar
First, it helps to think about C/R from a physical perspective--i.e. the volume uncompressed vs. compressed.
When you have a stock bore, say the volume of the cylinder 400 cc's when at BDC and 40 at TDC, which would be a 10:1 compression ratio.
When you overbore, you're only increasing the total volume when the piston is at BDC (uncompressed), it remains the same at TDC (compressed--picture the piston at TDC... the cylinder volume/bore doesn't matter because the piston is all the way at the top).
So basically you're going from
400 10
40 1
403 10.075
40 1
Its only ~8 100ths, but it definately does increase the C/R.
Old Aug 22, 2002 | 10:52 PM
sparkz's Avatar
The compression is increased but the difference is very tiny so its pretty negliable
Old Aug 23, 2002 | 05:08 AM
X2BOARD's Avatar
When you do a .25 overbore, the combustion chamber is not increased in size, only the actual cylinder. Also, the stock headgasket fits a .25 overbore without modification.
But following the simple explaination, I think I get it now. Although almost inconsequential, the bore does affect compression.
School's out !!!
Old Aug 23, 2002 | 07:38 AM
martini's Avatar
ah, but the combustion chamber does increase in size slightly, because your piston to deck clearance (distance from the "surface" of the piston to the deck), and the space between the top compression ring, and the "surface" (not the dome) of the piston.
and you're right, for hondas the stock headgasket works fine with a .25 overbore, but other engines you have to modify the headgasket.
anyways. I'm done.
cheers!
CrazyKoreanCrx
Feb 24, 2004 06:14 PM
advanracing62
Aug 3, 2003 03:38 AM
granada_sun
Jul 31, 2003 12:09 AM
RICHJ
Apr 15, 2003 06:58 AM
95gsr
Jan 16, 2002 06:56 AM
