Car won't start. Starting to piss me off.
Old Jan 12, 2009 | 12:32 PM
blake22's Avatar
Default Car won't start. Starting to **** me off.
I just put a new motor in my car and went to go start it and it cranks but doesn't run. It has no spark and no fuel. When you turn the key on the pump doesn't prime or anything. I have power going into the coil but no spark coming out. NEED HELP ASAP. Thanks.
Old Jan 12, 2009 | 05:56 PM
blake22's Avatar
Default Re: Car won't start. Starting to **** me off.
Anyone? Any ideas?
Old Jan 12, 2009 | 06:55 PM
P_Adams's Avatar
What engine did you put in what car?
Old Jan 12, 2009 | 08:14 PM
redline870's Avatar
what year and trim (ex, lx, dx)? what motor did you put in? jdm, usdm, vtec, non vtec? does this have an external coil? about the fuel pump, when you crank the engine did you open the valve on the fuel rail to ckeck for fuel pressure?
Old Jan 13, 2009 | 04:38 AM
blake22's Avatar
Its a 95 accord lx and i just replaced the blown up f22b2. So its the same engine. It has an external coil and i havn't checked for fuel pressure all i know is the pump doesn't prime.
Old Jan 14, 2009 | 06:34 PM
redline870's Avatar
if the pump doesnt work then it probably needs to be replaced
Old Jan 14, 2009 | 06:39 PM
GhostAccord's Avatar
Go back and check all of your power and ground connections. Make sure they are clean and tight.
and don't forget the engine harness ground that connects to the drivers side end of the intake plenum.
Just for starters......
Old Jan 14, 2009 | 07:09 PM
HONDAPARTSMANMIKE's Avatar
x2 check all engine grounds. does your cel (check eng. light) come on when to turn the key?
Old Jan 15, 2009 | 02:21 PM
masterkill455's Avatar
check the main relay and also see if there is power and ground at your fuel pump, if you do have power and ground at your pump, your pump is fried
Old Jan 15, 2009 | 02:23 PM
just thought of this one too make sure your dizzy is good and plugged in if theres no trigger to the computer from the dizzy it wont fire
Old Jan 15, 2009 | 02:56 PM
NeKe1point0's Avatar
masterkill had good advice, same situation happened to me one time, I bought a dizzy off ebay and it would click into the stock engine harness however the connection wasnt clean. The plastic casing wouldnt allow all the pins to make good solid contact (crappy egay design). I had to modify the harness and havent had a prob since.
may not be your issue.... depending on the condition, age, and handling of the dizzy during the swap, its possible it couldve been damaged.
x2 on checking the pressure at the rail and testing for current at the pump itself. if the power is there. then pump no bueno
A good multi meter is your friend in this situation... GL
Elijahdaniel
Feb 27, 2016 07:07 PM
Kid-jdm-teggy
Sep 13, 2013 09:20 AM
Domnificent
Jul 24, 2010 01:48 PM
SsB_Db8
Apr 30, 2009 07:29 PM
pbizzlegsr
Aug 27, 2004 08:55 AM
