Oil in the spark plug tube, just changed valve cover seal
Old Jan 11, 2009 | 04:19 PM
jose310's Avatar
Default Oil in the spark plug tube, just changed valve cover seal
Well i changed the valve cover seal about a month ago, and now i have 3 tubes with oil, i took the spark plug out and covered in fresh oil, is there any DIY thread on changing the o rings seals? or anything, thanks!
Old Jan 11, 2009 | 04:45 PM
kornerk12's Avatar
Default Re: Oil in the spark plug tube, just changed valve cover seal
its more than likely the seals under the rocker assembly
Old Jan 11, 2009 | 04:50 PM
jose310's Avatar
where is that located? and what do i need
Old Jan 11, 2009 | 04:57 PM
kornerk12's Avatar
http://www.hondaautomotiveparts.com/...LINDER+HEAD+(1)
number 19
Old Jan 11, 2009 | 05:05 PM
jose310's Avatar
what category is it under?
Old Jan 11, 2009 | 05:10 PM
ant$missShift's Avatar
cylinder head ... #19 Oring as stated aboce.
Old Jan 11, 2009 | 05:18 PM
kornerk12's Avatar
cylinder head(1). Sorry i thought that would take u straight there
Old Jan 11, 2009 | 05:19 PM
jose310's Avatar
ok thanks, so how i get to that ring?
Old Jan 11, 2009 | 05:21 PM
jose310's Avatar
Thanks alot, its just removing the 2 nuts right? on top of the cover
Old Jan 11, 2009 | 09:40 PM
jose310's Avatar
Do i have to take out the spark plugs out first before removing the valve cover?
Old Jan 11, 2009 | 10:48 PM
GhostAccord's Avatar
If you are asking if you need to remove the spark plugs first. You might what to get yourself an Accord manual before trying to replace the spark plug tube o-rings.
They are the ones below the rocker assembly (red). The rocker assembly requires certain removal and installation procedures that are found in the manual. Once you remove the rocker assembly it could possibly fall apart. And there are a lot of small parts involved. Therefore you would definitely need a manual to put it all back together.
Old Jan 12, 2009 | 09:27 AM
jose310's Avatar
Where can i get these Orings?
Old Jan 12, 2009 | 01:01 PM
professorman's Avatar
Old Jan 12, 2009 | 01:38 PM
NGUSPEED's Avatar
The 'O' Rings should have came with the valve cover gasket kit.
When you do this, becareful when pulling the rocker assembly. When I got mine off, the end two rockers came off and went all over the place. I managed to get it back together correctly, but it was a PITA. Also make sure you torque the bolts back to spec.
Jokergp
Sep 3, 2008 10:54 AM
Dj Skidz7
Apr 29, 2008 11:16 AM
square_1
Jul 21, 2006 11:14 PM
DrewQ1
Nov 9, 2004 04:48 PM
quazar
Jun 22, 2004 06:46 PM
