What temp/pressure senders to use with tunerview?...
Old Jan 11, 2009 | 03:59 PM
*Boostwerks*'s Avatar
Default What temp/pressure senders to use with tunerview?...
Anyone using autometer senders with the tuner view? HR informed me that any 0-5V sender will work for an input, but I can't find any tech info on the autometer senders.
The gauges I have are all short sweep with single wire senders. Will these work or do I need three wire senders?
Thanks,
Bryson
Old Jan 12, 2009 | 01:38 PM
96 GSR-T's Avatar
Default Re: What temp/pressure senders to use with tunerview?...
You only need 1 wire with a 0-5v output to send to the ECU, not sure I understand the question.
Old Jan 12, 2009 | 05:58 PM
sander's Avatar
2.7(p/t)
He is refering (HRtuning) to common linear 0-5V sensors that can come in all kinds of different scaling factors (1,2,3,5 bar etc)
0-5 V sensors NEED three wires.
Power (5V)
Ground (0V)
Signal (relative to measurement)
Your single wire autometer ones will not work.
Old Jan 13, 2009 | 03:42 PM
Power (5V)
Ground (0V)
Thats what I needed. Thanks!
Nsane
Sep 16, 2006 04:36 PM
SamC
Dec 14, 2005 12:07 PM
Ibuprofen
Feb 5, 2005 05:10 AM
4doorex
Audio / Security / Video
Feb 21, 2004 04:58 PM
