timing on civic
Old Jan 11, 2009 | 02:38 PM
8083tcman's Avatar
Default timing on civic
my car been sputtering alot so i decided to check the timing. well it was 20 degrees is this wrong?
Old Jan 11, 2009 | 03:14 PM
tweedersc07's Avatar
Default Re: timing on civic
check your sticker under you hood, i think its supposed to be 16 plus or minus 2 degrees.
Old Jan 11, 2009 | 05:30 PM
green99civic's Avatar
and you have to make sure that your with in 2 degrees because anymore could cause alot of vibration within the car on cause miss fire
Old Jan 11, 2009 | 05:35 PM
sql_civic's Avatar
It depends on the motor in your Civic.
Examples:
D16Y7 = 12 degrees BTDC
D16Z6 = 16 degrees BTDC
Old Jan 11, 2009 | 10:51 PM
8083tcman's Avatar
ok i have a d16y7 and its reading 20 degrees so its suposed to be on 12? and whats btdc is that top dead center?
Old Jan 13, 2009 | 03:47 PM
8083tcman's Avatar
Old Jan 27, 2009 | 05:03 PM
sql_civic's Avatar
BTDC=Before Top Dead Center
98bucket
Nov 21, 2010 03:57 PM
hahahaha123
May 15, 2010 06:15 PM
97vtec
Sep 23, 2003 10:25 PM
93JDMHONDA
Aug 11, 2003 12:03 PM
94civicx
Mar 23, 2002 04:50 PM
