TDC Sensor 8
Old Jan 11, 2009 | 07:37 AM
mikehawk's Avatar
Default TDC Sensor 8
Car is running .. idles very low but it starts and runs i'm throw code for TDC (top dead center) #8 what should I do? to resolve this issue?
Old Jan 11, 2009 | 07:44 AM
mikehawk's Avatar
Default Re: TDC Sensor 8
from what i've found in search it suggests a new dizzy.. true or false? Can I just drive it like this it runs fine?
Old Jan 11, 2009 | 07:46 AM
mitchell_2kSiR's Avatar
pull your positive battery post off . . tap your breaks wait 15 minutes and see if it goes away . . if it doesnt then you know something is wrong .
Old Jan 11, 2009 | 12:23 PM
mikehawk's Avatar
i've been driving it a little it seems to bog a little low in the rmps i dont know if the ignition timing is off a bit or what
Old Jan 11, 2009 | 12:24 PM
honda.lioness's Avatar
Partly true. The TDC sensor is one of the three engine control sensors built into the dizzy housing. An OEM dizzy housing by itself is cheaper than a whole OEM dizzy. Lots go aftermarket though. Aftermarket dizzies are not as reliable but often do the trick for some time.
It is possible that there is just a wire that is loose. Go to the shop manual at http://ww1.honda.co.uk/car/owner/workshop.html and see the tests for the sensor there.
I expect your gas mileage will improve with a new dizzy housing. IMO those three sensors do degrade with time. I recommend replacing the housing every 150k miles/10 years.
pos94accord
Jan 25, 2009 05:29 PM
firaga21
Oct 30, 2008 08:33 AM
honda_kid42
Jan 13, 2005 08:44 PM
snatch
Dec 13, 2004 04:28 PM
paybac4223
May 20, 2004 03:20 PM
