Should i pull the trigger on a Miller Syncrowave 250DX
Old Jan 11, 2009 | 12:20 AM
Vagmaster's Avatar
Default Should i pull the trigger on a Miller Syncrowave 250DX
Almost ready to order my miller Syncrowave 250DX should it be a go or there is something better and cheaper out there?
Old Jan 11, 2009 | 04:05 AM
weiRtech's Avatar
OG Fabricator
Default Re: Should i pull the trigger on a Miller Syncrowave 250DX
you won't regret it.
Old Jan 11, 2009 | 04:33 AM
frostyrb's Avatar
i just got a miller syncrowave 250 w/ the cooler & all the running gear for free. it"s not the new model, it is a 2000, but i love it. i have two torches hooked up on it. one small one for doing low amp welding & a bigger one for doing heavier work using alot of amps. make sure you get a cooler w/ yours too. if i were to buy a tig setup i would go with a dynasty only because it is a lot smaller(i am kinda limited on space) & it uses no where near as many input amps to operate.
Old Jan 11, 2009 | 08:18 AM
Blackcatn2o's Avatar
I'm sayin anything that is over a millermatic 140 (witch i have) would be good.
Old Jan 11, 2009 | 09:49 AM
dave@passenger's Avatar
A syncrowave 250 is a great machine, if you don't do much Al you might find that a dynasty 200dx better suits your bill, they are much smaller and use less power, also have more features.
Old Jan 11, 2009 | 10:32 AM
Agtronic's Avatar
Go for it, you will love it. I run a fabrication shop with a 185A machine, and it gets me by, even though I sometimes wish it had more juice. The 250 is a great machine, and you'll love it.
Old Jan 11, 2009 | 10:56 AM
intense4thgen's Avatar
i run one at work aswell really good machine and the cooling option is really a good upgrade to consider as well
Old Jan 11, 2009 | 11:49 AM
CVC9216's Avatar
why would the dynasty not be well suited for aluminum? I have not used one much but I have a friend running one off 110V temporarily and welding Al with it fine.
Old Jan 11, 2009 | 12:49 PM
I should have specified thicker than 1/4" Al.
An extra 50 amps is a lot if you want to weld 1/4" Al.
Old Jan 12, 2009 | 06:19 AM
turboteener's Avatar
Banned
I like mine. Make sure you get the watercooled torch. Way mo betta than aircooled when you are welding a long time or heavy stuff.
Old Jan 12, 2009 | 07:39 AM
m R g S r's Avatar
Think about how often you will be using the machine at full power, around 250amps. Thats a lot, most exhaust work and sch 10 or 40 pipe won't use anything near that. I'm thinking the only time you will be using the machine at full power is when doing thick aluminum. If you don't do a lot of aluminum work, then I'm sure you can get away with the cheaper sync200. Both are very large machines and are not meant to be moved around as easily as the dynasty.
If you look around you can find a sync200 and water cooled torch setup for less than the cost of the sync250 alone.
But hey, if you have the cash to burn, go for it. If you're looking to save a few bucks, I say go for the 200 and water cooled torch then use the extra cash for another machine that will be useful. A decent bandsaw, belt sander etc....
Silent9o8
Audio / Security / Video
Jan 5, 2006 11:27 AM
lsvtec101
10
Jun 5, 2004 09:53 AM
BnTBoz
12
Mar 22, 2003 06:48 PM
xXxS_SxXx
29
Jan 15, 2003 06:44 PM
degradated
10
Mar 24, 2002 05:59 PM
