brake question
Old Aug 5, 2002 | 09:22 PM
Razor's Avatar
Default brake question
what makes your breaks last longer?
a.) slowly applying brake from a distance until you stop
OR
b.) braking right before the stop sign or traffic light
isn't option 'a' the same thing as 'riding the breaks'? won't that wear out your brakes even quicker? also, i've heard that option 'a' can warp your rotors.
Old Aug 5, 2002 | 09:35 PM
Brandon's Avatar
Life is Suffering
Default Re: brake question (Razor)
OR
Lighter application is better.
Old Aug 6, 2002 | 05:14 AM
Stew Pidasso's Avatar
Less heat over a longer period of time is your friend.Choice "A".
If you come from a hard stop (say 90-0 MPH on an off ramp ) and hold your foot on the brake pedal,as the rest of the rotor cools,the part where the pad clamps the rptor will hold the heat causing uneven cooling and can cause warping that way.I sometimes put the car in neutral (although I wish it was a clutch) after a heavy brake on an off ramp or if the ground isn't level I'll stop a few extra feet back and slowly creep up with light pedal pressure to allow more even cooling of the rotors.
Old Aug 6, 2002 | 09:00 AM
KGAccord's Avatar
Default Re: brake question (Nitz5785)
What do they teach in drivers Ed?......
Lightly apply the brake before you stop.
Riding the brakes is when you hold the brake down a long hill.
Old Aug 6, 2002 | 04:17 PM
Razor's Avatar
Default Re: brake question (KGAccord)
thanks, i was just making sure. i always use light pressure over long distances anyways.
mandoski
Aug 24, 2018 10:41 PM
Ninja Mike
May 27, 2004 07:20 PM
MidNiteMysT
Jun 30, 2003 10:24 PM
