way too much fuel?? tried alot.
Old Jan 10, 2009 | 07:53 PM
96accordsir's Avatar
Default way too much fuel?? tried alot.
ok first off the problem is with an lsvtec. i got a p28 and a tuned p28. both have the same issue. i got a walbro 255 and everything is stock like rail,line,filter,regulator etc. the car was flooded and when i was testing the injectors by pulling the rail with them on it the car actually started a little with no injectors? then when the fuel was cleaned out of the cylinders and i put it back together it didnt take more than one crank to flood again. my timing is also on the white line(tdc) which i dont know is right or not? i tested the fpr on my other gsr and it worked fine? im confused so thats y i came on here. thanks?
Old Jan 10, 2009 | 08:58 PM
Default Re: way too much fuel?? tried alot.
please someone
Old Jan 10, 2009 | 09:17 PM
93formula's Avatar
what injectors are you using?
Old Jan 10, 2009 | 09:21 PM
obd2
Old Jan 10, 2009 | 09:29 PM
93formula's Avatar
resistor box?
Old Jan 10, 2009 | 09:30 PM
no
Old Jan 10, 2009 | 09:34 PM
efjones9's Avatar
if im not mistaken a p28 is a obd1 ecu. have u tried running a obd2 ecu? is it converted from obd-0bd 2??
Old Jan 10, 2009 | 09:35 PM
93formula's Avatar
try swapping injectors if you can...maybe they get stuck open?? it wont matter he can use obd2 injectors in obd1...also try to check with a volt meter, make sure your fuel pump primes and turns off like its supposed to...
Old Jan 10, 2009 | 09:45 PM
when i tested the injectors they dont stick open they just spray alot. and my fuel pump is a 255 so you can hear it turn off after prime.
Old Jan 10, 2009 | 10:32 PM
93formula's Avatar
try another set of injectors maybe, or could it be your tune? vacuum line to the regulator hooked up properly?
Old Jan 10, 2009 | 11:17 PM
thats what i was wondering about the line but there is no clog in the hose or intake mani so im pretty sure
Old Jan 11, 2009 | 02:24 PM
bump help
Old Jan 11, 2009 | 02:51 PM
shaggyeg6si's Avatar
Okay, you said they are obd2 injectors, are they civic or integra injectors, maybe prelude? The fuel pressure regulator, it is a stock regulator? Does it have a good vacuum source?
Old Jan 11, 2009 | 06:41 PM
i dunno what injectors. stock regulator. and it is attached the way it should be.
Old Jan 11, 2009 | 06:55 PM
EFstyle's Avatar
Old Jan 11, 2009 | 07:10 PM
93formula's Avatar
thats what i said, LOL, but yeah try to get another set of civic or integra injectors to try...
Old Jan 11, 2009 | 08:51 PM
ill try i might get some tomorrow and try it
WillU
Aug 29, 2013 10:04 AM
TeknikDC2
Jan 25, 2010 08:56 PM
xft
Jan 4, 2009 10:10 AM
Boost3d22
Mar 13, 2005 05:59 PM
