1999 civic no spark
Old Jan 10, 2009 | 02:27 PM
blu1840's Avatar
Default 1999 civic no spark
Well, today, I changed the spark plugs, wires and dist. cap. It worked fine after that , I drove home 60+ miles and had no problem. I started it after resting it for 4 hours to move and wash it. It started with no problems, but began to lose power. After I washed it, it would not start. It turns over but gets no spark.
What should I test??!!
Old Jan 10, 2009 | 06:30 PM
fastrc2's Avatar
Default Re: 1999 civic no spark
take the cap off the dizzy and look for wetness, sounds like a classic wet distributor, if in doubt, apply a spray that absorbs water like ignition wire drier. use a screwdriver as a stethoscope on the injectors, do they click when you crank it?
Old Jan 10, 2009 | 08:33 PM
Former User's Avatar
If the dizzy is dry, consider replacing the old plug wires.
Old Jan 10, 2009 | 08:44 PM
The_Honda_Guy's Avatar
Did you spray the engine bay down at all? If you, you most likely got water into the distributor cap which would prevent the wires from receiving the spark they need to fire the plugs. I'd pop the cap off and check to make sure there's no moisture in there. I've had this happen to me before and I simply dried the water out and the car fired right up.
Old Jan 10, 2009 | 11:10 PM
mikehawk's Avatar
get a cheap test light take the dizzy cap off put the key in the on pos see if you are getting power to the COIL
Noo_Ish_mee
Jun 27, 2016 02:44 PM
gizmo jdm
Nov 14, 2011 04:29 AM
ex_ricer
Aug 14, 2008 02:14 PM
ls19integra95
Apr 15, 2007 11:40 AM
EblazeK
Aug 4, 2006 01:02 PM
