d16y8 swap help asap
Old Jan 9, 2009 | 11:18 PM
king_pin's Avatar
Icon6 d16y8 swap help asap
hey there everyone
i have a 96 ek hatch swap into a 96 civic ex ( full swap, includ. EWH )
i have decided to use a obd2-obd1 conversion and a p28 ecu
for some reason my check engine light is on
i have replace the o2 sensor
my power seem to be short (lights flick)
and the car seem to blog and high idle
any help would be greatly appreciate
Old Jan 9, 2009 | 11:20 PM
king_pin's Avatar
Default Re: d16y8 swap help asap
bump before sleep
Old Jan 10, 2009 | 10:30 AM
king_pin's Avatar
bump before going to work
Old Jan 11, 2009 | 08:19 AM
jr_deleon's Avatar
If your check engine light is on did you jump it to see what the code is? Jump it and see what code it gives you.
Old Jan 11, 2009 | 09:58 AM
king_pin's Avatar
my obd2 code reader couldn't read it because im using a P28 ECU
can i do a obd1 check?
Old Jan 11, 2009 | 06:35 PM
jr_deleon's Avatar
You wouldnt read it with one of those scanners. Jump it as you would with an obd1 car (2 pin plug to the lower right of the glove box)
509ernie
May 26, 2012 07:22 AM
king_pin
Mar 8, 2009 11:11 AM
king_pin
10
Feb 8, 2009 10:01 AM
PhatwhipsJDMkits
Nov 27, 2004 11:47 PM
