No "True" Integra Lover Knows!!!!
Old Jan 9, 2009 | 05:47 PM
freedm's Avatar
Default No "True" Integra Lover Knows!!!!
I have been asking this question for quite a while now and a I never seem to get a clear answer.....I wonder if anyone truely knows!!
How do you read the "clock" info on the front of the engine head?
There are 4 "clock locking" emblems on the head...SO WHAT!!! How Do You Read Them
I am trying to fing the exact date and make of my engine but no one can help!!
I know, I know the block says B18C and nothing else...
They say the head has a mark on it but no one can tell me where...
Does AnyOne Know????????
Old Jan 9, 2009 | 05:56 PM
j_bizach's Avatar
Default Re: No "True" Integra Lover Knows!!!!
JDM SiR Block manufactured 95-97.
Its a JDM version of a USDM Type-R
Spec.
JDM Honda Integra Type R
Power: 214 hp @ 8000 rpm
Rev-limit: 8,700 rpm
134 ft·lbf @ 7300 rpm
Transmission Type: 5-speed standard with LSD
Displacement: 109.7 cu in
Compression:y 11.1:1
Bore: 81 mm (3.189 in)
Stroke: 87.2 mm (3.433 in)
Rod Length: 137.9 mm (5.429 in)
Rod/Stroke Ratio: 1.58
Transmission: J4D (96specR w/ LSD)N3E (98specR w/LSD)
Old Jan 9, 2009 | 05:59 PM
freedm's Avatar
AND???
what does that tell me?
I am trying to find the exact year and if it is a jdm GS-R or a JDM type-R
how do I find out?
...and thanks for your quick reply!!!
Old Jan 9, 2009 | 06:01 PM
j_bizach's Avatar
Originally Posted by freedm
AND???
how do I find out?
Its a JDM version of the USDM Type-R
Exact date shouldt matter
Old Jan 9, 2009 | 06:04 PM
freedm's Avatar
I agree but it matters to the owner...LOL! I am just curious how to find the date...
and how are you sure its the type-r and not the gsr..Theres a differance of 180 hp to 195 hp...thats something else I would like to know..
and with all honesty...THANK YOU j bizach for speaking with me!!! (The name cracks me up too)
Old Jan 9, 2009 | 06:11 PM
j_bizach's Avatar
Well ud proly have to find someone who works at a honda plant the marks that u talk about are production line marks that are only really used by the factory to help identify problems with casting and production mistakes.
Do you have the head that came with the motor
The head will tell you which it is
Old Jan 9, 2009 | 06:18 PM
freedm's Avatar
Yes I have the original head..but where is the markings?
Old Jan 9, 2009 | 06:19 PM
freedm's Avatar
and it deffinatly doesnt have LSD
Old Jan 9, 2009 | 06:25 PM
j_bizach's Avatar
i believe that its on the intake side off to the side and above to intake ports
Old Jan 9, 2009 | 06:26 PM
j_bizach's Avatar
p72 is gsr and p73 is type r
Old Jan 9, 2009 | 06:28 PM
j_bizach's Avatar
alrite its on the exaust side above the 4 cyl exaust port
Old Jan 9, 2009 | 06:29 PM
freedm's Avatar
OK!!! now we're getting somewhere!!! I do see P72 so I assume I have the gsr..No Problem That is very acceptable!..now to find out how to find the exact date of engine...is the 95-97 all OBD1 for JDM?
Old Jan 9, 2009 | 06:44 PM
j_bizach's Avatar
lol alrite here the deal not all are obd2 95 is obd1 then in 96 the standard went to obd 2 so a 96 nd up is obd2 now how to tell the diffence is waat im figuring out.
Old Jan 9, 2009 | 06:53 PM
freedm's Avatar
no heres my delima...i'm trying to put this engine in my 90 crx...I need to know if its obd1 or obd2..thats why I need to know so I can figure out which jumper harnesses ect...It's pretty crazy.I'm to the point I need to wire this up!
Old Jan 9, 2009 | 06:54 PM
dkrex001's Avatar
Old Jan 9, 2009 | 06:55 PM
freedm's Avatar
thanks for your time j bizach...as soon as all this is done ...I will be listing a post so others will know all the info I know..and that you helped me figure out!!!!!
Old Jan 9, 2009 | 06:58 PM
freedm's Avatar
you are sure of this dkrex001 ? Do you know what the other numbers stand for?
and is this a pic of an integra motor or civic?...just making sure there is not a differance in the way they dated them...ya know?
thanks!
Old Jan 9, 2009 | 07:03 PM
freedm's Avatar
mine engine shows 9/3..I would assume this makes it a 94?..the first year they made them
Old Jan 9, 2009 | 07:05 PM
j_bizach's Avatar
thanks!
The jumper harness for obd1 round and yellow
obd2 gray and square
Old Jan 9, 2009 | 07:06 PM
shy_lee85's Avatar
Originally Posted by dkrex001
this is definitely for sure...this is how you tell..
Old Jan 9, 2009 | 07:10 PM
freedm's Avatar
they didnt make a B18c in 93 so I would be safe to say that mine is a 94? OBD1
Old Jan 9, 2009 | 07:17 PM
j_bizach's Avatar
nope they didnt make a b18c in 94 does the motor hav a harness that come with it
Old Jan 9, 2009 | 07:23 PM
freedm's Avatar
yes it does have the original harness...I know its not an obd0 harness..and I'm not sure what an obd2 harness looks like
Old Jan 9, 2009 | 07:32 PM
all-mtr-teg's Avatar
If your head says 93 then it's a 94 motor. Lots of heads were cast in 93 and used in 94 and even 95 motors.
Old Jan 9, 2009 | 07:38 PM
freedm's Avatar
Thanks all-mtr-teg!!!! Your stern post gives me confidence!...Any idea what the other "clock" numbers mean for curiosity sake?
Thanks again!!
