Throwing a JDM B18c Gsr Into a 94 Integra LS
Old Jan 9, 2009 | 04:14 PM
jdm_vizionz's Avatar
Default Throwing a JDM B18c Gsr Into a 94 Integra LS
I have a jdm B18c that we pulled out from my old yellow 88 crx si before I sold it. I was told when I got the CRX, that it was a 96 jdm B18c. I have a 94 Integra LS right now. I was wondering if you guys can help me. I'm not a pro at the mechanical stuff. I knoe a few stuff but not everything. I want to drop it into my 94 LS but I think the B18c motor is OBD2 and throw my 97 LS Tranny on it. What would be everything I need to make the engine run? Can Anyone help me? Can I use the LS Engine Harness with the motor, and just get an OBD2 to OBD1 converter? Or Do I have to get an OBD2 GSR Harness and get the OBD2 to OBD1 Engine harness?
Old Jan 9, 2009 | 11:27 PM
Default Re: Throwing a JDM B18c Gsr Into a 94 Integra LS
Bump. Any help would be appreciated. Thanks.
Old Jan 9, 2009 | 11:30 PM
ekb16's Avatar
use ur stock harness..everything will be plug n play except for a few sensors u will need to add wires for..find urself a 0bd1 p72
Old Jan 9, 2009 | 11:31 PM
vietnamezerice's Avatar
you can use the B18c just make sure you use a OBD1 engine harness... as far as the tranny, it won't matter, any b-series will do
Old Jan 10, 2009 | 02:24 PM
AnDThEnWuT's Avatar
Its a straight forward swap, just need additional wires for vtec and I believe one for the knock sensor and a 0bd1 ecu like the p72 or chipped p28.
Old Jan 10, 2009 | 02:30 PM
josh_mac17's Avatar
I have a OBD1 JDM P72 ECU if you are interested.
Old Jan 10, 2009 | 03:18 PM
Thanks but I have a jdm chipped P72 ecu already. Thanks for all the help guys. I would be lost without you guys.
Old Jan 10, 2009 | 07:15 PM
Old Jan 10, 2009 | 10:48 PM
mouab18c1's Avatar
what about the main dizzy harness? dont obd1 cars have two plugs and obd2 have just one? do you just leave one of them hanging? just to clerify
Old Jan 12, 2009 | 01:26 AM
if he's using an OBD1 engine harness then he won't have to worry about anything unplugged... there's no sense in using an obd2 engine harness in his obd1 teg
Old Jan 12, 2009 | 02:45 AM
NAV_GUNZ's Avatar
http://www.jspecauto.com/page.aspx?page_id=17
Check out this site it will tell you everything you need to have to do the swap..
Old Jan 12, 2009 | 07:08 AM
mouab18c1's Avatar
well his motor is an obd2 motor...i dont think you can run obd1 dizzys on obd2 motors...so if im thinking right..using an obd1 harness on an obd2 car he will have an extra dizzy plug hanging..why? cause obd1 dizzys have two plugs while obd2 cars only have one..get it? and since he is running an obd1 ecu wouldnt the ecu throw a CEL? if its not plugged?
Old Jan 12, 2009 | 09:11 AM
jdmdc2boi12's Avatar
good info
Old Jan 12, 2009 | 07:18 PM
civicgsr499's Avatar
take this advise from me... dont use an ls tranny with a gsr motor. its good for highway driving but the longer gears kill it. sell ur ls tranny and spend a few extra hundred and get a gsr. but then again, i have a bad input shaft bearing in my ls. so that gives me a good reason to get a gsr hahaha
Old Jan 12, 2009 | 07:24 PM
you CAN use an OBD1 distributor on ANY LS, the actual motor doesn't make it OBD1 or OBD2... the alternator, injectors, engine harness determines what OBD the swap is.. you can not use a OBD1 engine harness on a 96+ Integra (OBD2) it will not run... the wiring to the ecu is completely different for OBD1 and OBD2
Old Jan 13, 2009 | 07:05 AM
mouab18c1's Avatar
who was talking about using an ls dizzy? and my question is if he is using an obd1 ecu wouldnt his car throw a CEL because he would have an extra connector hanging since obd1 cars have 2 plugs for the dizzy? i know it would run but the ecu CEL should come on....so what your saying is that he needs an obd2 harness? cause from what i understand he's going to use his ls harness whihch is obd1 for the JDM b18c since he thinks its an obd2?
Old Jan 16, 2009 | 06:30 AM
I was wondering if i would need a conversion harness for the ECU? And is it difficult to wire vtec to the LS?
Old Jan 16, 2009 | 06:35 AM
scbmx87's Avatar
If you're using your obd1 harness, and the ecu is obd1, then no you don't.
As far as the vtec wiring, i think its only 2 wires. I'm not sure though.
Old Feb 22, 2009 | 11:04 PM
bladgghjgjsg293's Avatar
if you haven't already check this out:
http://rywire.com/store/9400-integra...ess-p-115.html
Looks like maybe all you need is the vtec subharness but if not they have ecu jumpers and dizzy converter plugs as well.
Old Feb 23, 2009 | 07:08 AM
EJ6 BoOsT's Avatar
im throwing a b18c1 ob1 (GSR) on my 95 LS also and should i get that ry wire or just add any wire for vtec
Old Feb 24, 2009 | 06:44 PM
i guess it depends on how good you are doing your own wiring and how much you wanna spend on it. I'm dropping a 94 gsr (b18c1) into a 90 LS, so that's OBD0 -> OBD1. I gotta think about a lot more -- vtec,ecu,dist,injectors,.. So.. I decided to go w/ the rywire. I'd rather get it right now and not throw codes once I get everything dropped in cuz it's kind-of a b..ch lol
i'll let you know how it goes when it's done.
some ppl i've talked to seem to think it should be easy.
Old Mar 17, 2009 | 10:27 PM
swap is mostly done, few loose ends to tie together but it's driveable. (no power steering yet )
rywire harness worked great, I think it was worth every penny of the $190 but then again I was doing obd0 -> obd1. I think w/ a 95 LS if it's already obd1 there's less to think about. With the gsr motor you will just have vtec, oil pressure, and IAB if you're using stock manifold.
9818tegr
Mar 25, 2009 03:11 PM
93(Civic)EG6
Aug 6, 2007 07:56 PM
be18see1
Apr 30, 2007 04:24 PM
94IntegraLs04
Jul 23, 2005 03:48 PM
