b18a1 with ls rods and b16 pistons??
Old Jan 9, 2009 | 12:05 PM
knightsef-eg's Avatar
Icon3 b18a1 with ls rods and b16 pistons??
hey just wondering how it would be?
iv searched and found nothing
b18a1 pr4 block
with oem pr4 b18 rods..
and pr3 b16a pistons
what would the diffrence be from pr3 to pr4 rods
i have a pr3 crank aswell
let me know thanks
Old Jan 9, 2009 | 02:24 PM
AMLS4dr200whp's Avatar
Default Re: b18a1 with ls rods and b16 pistons??
b18a1 pr4 block
let me know thanks
what happen to ur ls crank? the difference is the length on them between the rods
Old Jan 9, 2009 | 02:30 PM
ok well iguess i should use the stock ls crank .... what rods / pistons should i build i want it to be able to stand a turbo when i install it later
Old Jan 11, 2009 | 02:52 PM
LA_HONDAS's Avatar
you use a ls block ,crank and rods thats it
then you get some b16 pistons and get them put on the ls rods then take the pistons and the block to a machine shop to get it honed to OEM specs
Old Jan 12, 2009 | 11:09 AM
awsome thanks..... how much boost do you think that could handle?
should i do eagle H beams and some turbo pistons?
Old Jan 12, 2009 | 11:22 AM
gibsanez's Avatar
That depends on how much power you want, how much you're willing to spend, and how long you want it to last. Picked out something to tune with yet?
Old Jan 13, 2009 | 05:32 AM
LA_HONDAS's Avatar
well a ls block with b16 pistons your c/r will around 10.8:1 to 11.0:1 c/r with a vtec head it will be even higher
if you want to boost it go and get some eagle rods and some pistons like CP,JE,ETC,ETC
you will be looking at about $1000 if not more to build your bottom end and that for everything
Old Jan 14, 2009 | 05:54 PM
yea i just dont know how much i can boost stock internals to..
yes im gonna swap a vtec head on aswell
i was looking at yes hate if u want egay at the eagle h beams and wiesco pistons
and 1000 bucks to build it up im willing to do it.... cause i was hoping to get a good head seat up and boost to like 20 psi .. my ls crank will be balanced and polished
as for tuning im not sure but i would get the set up tuned for 20 psi ...
as for the head i have a b16a1 pr3 head with skunk 2
valves
springs
retainers
turbo 2 cams...
would pr3 pistons and LS rods hold up to 20 psi??
Old Jun 17, 2012 | 01:18 AM
Douglas Norwood's Avatar
thats not a really smart idea bro im doing the same build with out turb0 your compression is almost at 12:1 thats high a heck for boost
post some feedback
hp torque
etc
ez2000si
Mar 4, 2013 01:12 PM
Demerica333
Aug 26, 2009 05:47 PM
CTR_B
Nov 9, 2008 05:54 PM
mrbsponge
Apr 28, 2005 08:01 PM
GumballNA
Aug 5, 2004 02:49 PM
