Valve adjustement=loss of preformance?
Old Aug 5, 2002 | 06:50 PM
Francois's Avatar
Default Valve adjustement=loss of performance?
I'm wondering since it is noisy out there!
I believe my valve are in need of adjustement,since I didn't play with that for now.
I have done a lot of things since the day the B16 is in my car.
But now,it's time for valve adjustement.
May I re-gain somemore after?
All the rest is fine.
Takes no oil or coolant.
Has great compression.
Any help greatly appreciated.
[Modified by Francois, 10:51 PM 8/5/2002]
Old Aug 5, 2002 | 07:03 PM
the DR.'s Avatar
Default Re: Valve adjustement=loss of performance? (Francois)
you may gain some performance, not much but you might
see.. over time the vavle lash get wider and wider (by fractions of an inch, but still it gets wider) so in turn that means less lift for the vavles
Old Aug 5, 2002 | 07:08 PM
4gvtec's Avatar
Default Re: Valve adjustement=loss of performance? (CIVICtypeS)
exactly,noisy valves or really rocker arms,with wear get loose less power.meaning the valve does not open all the way,less air in and less air out.tight valves lose power also it does not let the valve shut.means **** compression,or loss of.
Old Aug 5, 2002 | 07:09 PM
crx(gator)'s Avatar
i was told your suppose to check and adjust your valves accordingly every 15,000 miles...
Old Aug 5, 2002 | 07:19 PM
Francois's Avatar
Default Re: Valve adjustement=loss of performance? (crxgator)
Mouhaha!
According to my calculation to convert from mile to km,I'm just in time for that!
Thanks for your answer guys!
GSRVTEC1
Oct 31, 2005 01:19 PM
Tad
20
Aug 26, 2004 04:31 PM
P1mpSlap
Jun 22, 2003 08:32 AM
HavokB18
18
Jan 7, 2003 08:50 PM
