Flat faced valve issues/advantages?
Old Jun 21, 2003 | 12:54 PM
P1mpSlap's Avatar
Default Flat faced valve issues/advantages?
I'm just wondering if flat faced valves will do anything other than raise the compression a slight bit. Is there any benefit of having them?
Also, running an agressive cam profile, and using the flat faced valves. Would one encounter valve : piston clearance problems (Standard size)?
Old Jun 21, 2003 | 01:51 PM
IN VTEC's Avatar
Default Re: Flat faced valve issues/advantages? (P1mpSlap)
Piston-to-valve clearance issues won't change b/c of the face of the valve.
They'll contact the leading edge of the valve before anything else.
Valve diameter dictates piston-to-valve clearances.
There might be something to talk about in theoreticals on intake charge tumble/swirl and burn characteristics and optimization, but practically-speaking I don't know of any significant benefit to that aspect alone.
Maybe it's just easier to make the valves flat-faced and that's why they come that way.
Old Jun 21, 2003 | 10:35 PM
Fkned2003's Avatar
Flat faced vales flow better than dished face on the exhast valve side.Flow going towards the exhast valve will react like a spoon turned face up under water. Flat faces have a much better smoothing effect on the air as it exits the chamber.
Old Jun 22, 2003 | 08:32 AM
Padawan's Avatar
Darth ModerVader
One disadvantage that comes to mind is the additional weight of the valves. With all of the individuals dead-set on running Ti retainers on their high-RPM setups, using heavier valves seems somewhat contradictory.
That being said, I don't know the exact weight figures, and there would probably be no problem running them on a moderate setup with the proper springs. I may infact look into these in greater detail for use in my brother's setup. Combined with a thinner headgasket, they would be a relatively easy (though not altogether inexpensive) way of boosting compression somewhat without touching the bottom end or sending the head out. When all is said and done however, I think the cost/benefit ratio will rule them out.
flat out 99
Nov 26, 2011 02:00 PM
pr3lude1992
Apr 1, 2009 05:33 AM
SpoolnByYou
Mar 16, 2006 12:49 PM
Tad
20
Aug 26, 2004 04:31 PM
