reving low with A/C on
Old Jan 8, 2009 | 07:27 PM
thatsmyhonda's Avatar
Default reving low with A/C on
ok after car is running at normal temp i turn a/c on and it blows cold but motor revs at like 200 rpm.. when driveing and let off gas to stop, car sometimes turns off at the light... whats the problem?
Old Jan 8, 2009 | 09:40 PM
gstrudler's Avatar
Default Re: reving low with A/C on
either the idle set screw on the tb is set too low or you have a faulty iacv (intake air control valve). to test the idle level, with the car running, unplug the electrical connector from the iacv (it's the extra little thing on the front of the intake manifold; it has one electrical connector and two small hoses (coolant) running to it). what happens?
Old Jan 9, 2009 | 05:10 AM
preluderemis's Avatar
could also maybe be a faulty a/c compressor...
Old Jan 9, 2009 | 05:12 AM
95ludeSE_bottle's Avatar
my car was doing the exact same thing- and it got worst as time progressed. it got to the point where when i would clutch it , it would go dead. of course i never figured out the problem due to the fact my motor died (RIP) a cpl weeks afterwards. So if u do figure out the problem, please post it so i can check that on mine when/if i get the motor back working.
Old Jan 9, 2009 | 05:23 AM
bb4arson's Avatar
200rpm bakaw! thats way low bro
Old Jan 9, 2009 | 05:51 AM
my old motor used to that because of an oil pressure problem...does your oil light flicker on???
smichka
Nov 27, 2013 11:23 PM
King_Kong
Nov 11, 2006 06:31 PM
DrewDown
Jan 1, 2005 03:45 PM
Gs-RAW
May 13, 2003 08:03 PM
