Battery Relocation ...Yes its been asked....
Old Aug 5, 2002 | 06:23 PM
FUP23's Avatar
New User
Default Battery Relocation ...Yes its been asked....
And ive searches just didnt get answes i needed.....Ok so i have 4g wire Im runing to the back of the car ..what do i do about the 10g wire that runs from the battery to the fuse box ?? can i run it off the starter ??? Ya know what i mean .. ? Thats all im confused about thnks guys --
2nd times a charm
[Modified by Devin17, 10:37 PM 8/5/2002]
Old Aug 5, 2002 | 06:38 PM
Francois's Avatar
Default Re: Battery Relocation ...Yes its been asked.... (Devin17)
Both of my stock location cable are still in the front.
I just bolted the ground on the frame.
The positive one is wired with the cable(+) coming from the back.
Ground battery is bolted near the shock tower.
This may not look right at a show but since I'm not a show freak,it is plenty reliable on the street and on the track.
Old Aug 5, 2002 | 07:11 PM
bryant's Avatar
Default Re: Battery Relocation ...Yes its been asked.... (Francois)
Just dis connect your batter from the where it is now. Run the possative from the starter back to the battery in the back. Ground the battery that is in the back to something in the back. like that metal peice right in the spare tire well. The power line that runs from your fuse box thing in the engine bay to the start will still stay there, in the engine bay. HTH.
Old Aug 5, 2002 | 07:14 PM
FUP23's Avatar
New User
Default Re: Battery Relocation ...Yes its been asked.... (CR-X)
thanks ...what size fuse should i run ?
Old Aug 5, 2002 | 08:52 PM
Trevor's Avatar
I have my batt in the back also. All you have to do is run the main wire from the battery to the front of the car. Then from that wire use a distribution block,(you can get at any stereo shop), mine is 0 gauge in with four eight gauges out. from that block run one to the fuse box and one to the starter. My turned out pretty clean and I only have one wire going to the back.
Old Aug 6, 2002 | 12:14 AM
nihkon's Avatar
Default Re: Battery Relocation ...Yes its been asked.... (CR-XSI)
What I did was I went to Lowe's and found this wire splice type thing. I don't even remember what section of the store it was in or what it was really meant for. hehehe
but anyways. . it's this little metal tube type thing with a set screw on each end. I ran a 4 gauge wire from the battery i nthe back up to the engine bay. Then I just crammned the wire into one end of the new splice. Then the 2 10 guage (I think) wires that are left over, you cram into the other end of the splice. Then I used some shrink-wrap to seal the connection up. And finally added some conduit to cover it all and make it look clean. Honestly it looks stock.
I'll take some pics tomorrow.
Old Aug 6, 2002 | 01:14 AM
D16Z6racing's Avatar
Default Re: Battery Relocation ...Yes its been asked.... (nihkon)
In my CRX I ran 4 gauge from the starter and fuse box to the back. + my ground off the battery was 4g. 10-12ft of each to the back and 2ft of ground. Never had a problem.
cubnsensation
22
Feb 23, 2018 09:11 AM
upgrayedd
Apr 17, 2010 09:04 PM
smash fascism
Apr 6, 2005 03:03 PM
JDMBOOGERHATCH
Mar 12, 2005 09:06 PM
nevin
Aug 9, 2003 03:53 PM
