car wants to die
Old Jan 8, 2009 | 10:17 AM
dc2_916's Avatar
Icon2 car wants to die
okay here's my problem,car is a 95 gsr when i do a hard u-turn the rpm would drop really low and seems like it wanna die. what can be the problem.and sometimes when i come to a complete stop the car rpm would rise up and drop really low . whats should i do or change
Old Jan 8, 2009 | 01:28 PM
lmike6453's Avatar
Default Re: car wants to die
This happens to me too. It seems like it has something to do with my power steering pump.
Old Jan 8, 2009 | 02:10 PM
Shawn C's Avatar
In The Garage
i was gonna say... sounds like the car needs a tune-up and the power steering pump is dragging down the engine enough to almost kill it. pop the hood with the engine running and inspect the pump (is it makin any noises?) i might even try removing the power steering belt, and check to see if the pulley spins nicely, or is there hesitation? or can it wobble?
most likely just needs a tune-up, though
Old Jan 8, 2009 | 02:32 PM
lmike6453's Avatar
In my situation, the pulley is 5K miles old, does not wobble, and tension adjusted correctly.
Old Jan 8, 2009 | 03:40 PM
Shawn C's Avatar
In The Garage
yeah, i didn't really suspect a ps pump problem. i'd say a set of ngk bkr6e's, some ngk blue plug wires, and maybe a new dizzy cap and rotor will fix your problem. on top of that, i'd say all air passages in your engine could use a nice cleaning (throttlebody, intake manifold, iacv, valves, and head ports and combustion chambers. and i don't mean running any kind of cleaner through it, i mean physically taking it apart and cleaning all the carbon buildup off. slap on new head, intake manifold, and throttlebody gaskets, and i'd say she'll run great. might even need a good chip tune (S300, crome, etc.). make sure your grounds are all good, too.
ludelover86
Apr 10, 2013 12:00 AM
wallendiaz
Nov 23, 2012 06:02 AM
dstockbridge
Mar 25, 2012 03:50 AM
htwitr01
Nov 2, 2010 08:56 PM
