my lude wont start f22 swap h23
94 lude put h23 in it used everything off the f22 except i bought a new distributor for a h23 retimed it cause wasnt sure if the previous owners did something wrong but it cranks gets fire gets gas but wont start do i need something else? i heard i might need a p13 what is that anyway/
i checked the timing the compression is 150 on number 3 and o on the rest sounds like timing to me but lined up the cams with the word up straight up on both and the marks on the side lined up to the surface of the head also lined up to match each other ,crank on tdc ,and the fly wheel on the white line with the teeth maybe head gasket or cracked head? its supposed to have been rebuilt so it shouldnt be the rings i hope
rhdune16
Jan 1, 2006 02:51 PM
